  • Dot Guests: 286
Author Topic: engine stand  (Read 4804 times)
engine stand
« on: February 20, 2010, 09:25:32 AM »
check this photo out.
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=21&g2_itemId=13519
can anyone tell me whether this is just 2 arms off the stand and if 2 arms is enough to support a small block chev? i can see its been modifyed so you can keep the flywheel on while on the stand..
cheers ben
Offline hunterbynature
Re: engine stand
« Reply #1 on: February 20, 2010, 09:30:27 AM »
i think you will find it has 3 arms ben, 2 is not enough to hold the weight, i have 4 on mine, can post you a pic if need be, they are all adjustable cheers stevo ;D
The Cheeky Kiwi
Re: engine stand
« Reply #2 on: February 20, 2010, 10:41:37 AM »
They have 4 arms. I'll get you a better photo later if you want it. Mine can support engines with the flywheel on too.
Re: engine stand
« Reply #3 on: February 20, 2010, 11:29:49 AM »
yeh i have a couple of engine stands and they both have 4 arms but i need to modify them so the flywheel can stay on as well..
if i just get some thick tube i guess i could just use them as spacers hey..
Re: engine stand
« Reply #4 on: February 20, 2010, 11:40:16 AM »
I wouldn't bother going to the trouble of replacing the tubes. Just make some spacers with some thick plate.
Re: engine stand
« Reply #5 on: February 20, 2010, 03:15:13 PM »
Hey Guys....I was just wondering,,,do those engine stands bolt up to the bell housing holes?
Re: engine stand
« Reply #6 on: February 20, 2010, 05:34:15 PM »
That is correct ;)
Re: engine stand
« Reply #7 on: February 20, 2010, 05:49:09 PM »
if your going to do the engine ahd bellhousing make sure you extend the legs for stability, other wise it will go over
