  • Dot Guests: 364
Author Topic: Front Spring Height  (Read 16494 times)
Front Spring Height
« on: January 17, 2010, 08:37:45 AM »
I'd like to ask a favour of someone with a facelift model SWB van that is still relatively standard.
When your van is next sitting on a level surface would you be able to measure from the ground to the top of the front wheel arch for me. It would be good if you could measure both sides and take an average just in case of spring sag.
It has to be the facelift model as these came out with 14" wheels and larger wheel arches than the original.
The reason I need this is that because I have a mid-mounted engine the weight has been moved back off the front cross member and as a result the front of the van is sitting much higher than it should be. I have to get my front springs reworked to bring the front back down to the correct ride height and thereby hopefully helping to sort out the wheel camber at the same time.
If a couple of people could do this that would be even better.
Thanks
« Last Edit: January 17, 2010, 09:11:25 AM by Rogue Trooper »
Re: Front Spring Height
« Reply #1 on: January 17, 2010, 09:51:11 AM »
Rouge
What is a "FaceLift" model ?
« Reply #2 on: January 17, 2010, 10:30:26 AM »
The facelift model is the 80's square shaped look like Jeff's.
It has the big black plastic grille and the large square tailights.
Offline Jeff
« Reply #3 on: January 17, 2010, 10:43:07 AM »
Rogue, that was interesting!
RHS front........720mm
LHS front........735mm
Rears..............755mm
Thats on 205x70s  pointing straight ahead. My van rides high....I'm sure, because the ld28 is set back about 150mm,..... and it slants to the right, so that may account for the lower height on that side.
« Last Edit: January 17, 2010, 10:44:48 AM by Jeff »
Funny old life.
« Reply #4 on: January 17, 2010, 11:52:09 AM »
That was quick. Thanks Jeff.
Mine is currently sitting at...
Both Front.......765mm
Rears...............755mm
That's sitting on 245/60/14s all round.
The front is measured at the moment with no engine in. I was going to put that in this weekend but our ratshit summer put paid to that quite nicely so it is now postponed till next weekend.
The tyre pressure in the rear is down a little from sitting so long so that may come up a couple of mm but won't be terribly much. Hope we can get a few more measurements from a couple of others to compare.
« Last Edit: January 17, 2010, 12:10:34 PM by Rogue Trooper »
Offline Marky
« Reply #5 on: January 17, 2010, 12:00:39 PM »
 L + R front 720mm
L + R Rear 750mm
I running  16" Rims with 225/65 tyres
« Last Edit: January 17, 2010, 12:04:00 PM by Marky »
Creative Media Producer
« Reply #6 on: January 17, 2010, 12:12:24 PM »
Thanks Marky but is yours the facelift model? I understand that there were very few of them in Aus. Wheels need to be 14"s as well to try and get as accurate an indication as possible.
Offline Jeff
« Reply #7 on: January 17, 2010, 12:22:26 PM »
Careful Rogue, or you may end up with flat spots in your tyres. Best to pump them high if its going to be sitting long.
Funny old life.
Offline Marky
« Reply #8 on: January 17, 2010, 12:24:54 PM »
Nup sorry Rogue mines a CF1......
Not many CF2s here in oz
whats the deal with calling it a facelift Model?
CF2 is easier to understand ;D
« Reply #9 on: January 17, 2010, 12:28:47 PM »
It is easier but not correct I'm afraid. Very few of the facelift models were actually CF2s. The CF2 came along later after the facelift and was another type of beast again with things like front discs as standard equipment.
