  • Dot Guests: 339
Author Topic: Ideas for door trims  (Read 7579 times)
« on: January 12, 2010, 11:22:37 AM »
Just wondering what materials and designs people have used for their beddie door trims? ;D
cheers..johnno
Offline weasil
Re: Ideas for door trims
« Reply #1 on: January 12, 2010, 04:49:34 PM »
hey john Im doing my wrap around dash I got of ben and my moulded  door trims in carbon fibre (look paint effect you can find this procedure on youtube )started as a joke but with practice I have done side mirrors house downpipe  and this method realy looks like carbon fibre  may look spartan but some paint effects look the biz.with a little practice there are a few styles on you tube but the guy who paints the door trim bits is the one
weasil
Offline Clappers
« Reply #2 on: January 15, 2010, 11:47:57 AM »
I used MDF to make my door trims. Its easy to work with and have incorporated my winder mechanisms and speaker mounts in. Once you finish shaping them spray them with some good urethane and then you can cover them in whatever you want. I intended to get a company in Perth that uses vacuum wrapping so it sucks the vinyl on just like a late style door trim. I also used MDF to make all my storage compartments in the rear.
"Goes like the Clappers"
« Reply #3 on: January 15, 2010, 07:15:03 PM »
Thanks for that clappers... ;) What thickness mdf did you use on your door trims?
« Reply #4 on: January 15, 2010, 08:12:04 PM »
I made these about 15 years ago out of thin MDF, some vinyl leatherette and velour. It looks a little beaten up after being stored for a while. Will make some new ones when I get that far but will probably try for something along similar lines. I used the arm rest and map pocket from an early Mazda 323.
Offline cfjeff
« Reply #5 on: January 15, 2010, 08:48:19 PM »
here is a picture of the ones I made last year for my CF. slab of 6mm MDF, handful of xmas tree clips, piece of tin (colour steel), some gray vinel, some red dravlon and a bit of foam. Put it all together and finish with a staple gun.
Just customize it!
« Reply #6 on: January 15, 2010, 09:41:34 PM »
Hey jeff...Does that bottom grey bit have a speaker behind it by any chance?
« Reply #7 on: January 15, 2010, 10:59:40 PM »
Ive been toying with building a bead roller and then making some door skins out of alloy with patterns rolled into them.
Offline cfjeff
« Reply #8 on: January 16, 2010, 05:44:16 PM »
No i'm sorry it dosen't have a speaker behind it, just added that bit because the panel looked a bit plain. So after much sitting and stairing at it decided to take the oval metal panel that is behind the door opener and cut its shape into the door panel.
Cheers Jeff
Just customize it!
Offline Abodator
    • My CF280
« Reply #9 on: January 16, 2010, 08:18:37 PM »
Some example from Italy.
« Last Edit: January 16, 2010, 08:22:30 PM by Abodator »
We are living in Ukraine, me and my vans: Vauxhall Bedford CF280 (1980) and Opel Bedford Blitz CF250 (1987) ;-)
