  • Dot Guests: 230
Author Topic: converting back wheels to Holden stud pattern  (Read 10056 times)
Offline matty
Re: converting back wheels to Holden stud pattern
« Reply #10 on: December 12, 2009, 11:03:40 PM »
how has the master cylinder handled the rear disk set up?
 have you had to add in a porpotioning valve on the rear line, or change to a later model master cylinder?
aka5000
« Reply #11 on: December 13, 2009, 12:17:35 PM »
im running lj booster with lh master, hits the bonnet tho, havnt got around to changing it. the guy at better brakes where i bought all my parts removed a small valve from the master cylinder as i told him its for a 4 wheel disc set up.
proportioning valves are needed for rear drums when running front discs because you use the front brakes more then rear.
i did the 4 wheel disc conversion all at once so i can really compare it with just front discs, coz yeah didnt want to carry 2 spares.
a mate did the same set up of com rear discs on his torana, this is really a very good set up.
ill get a wheel off sometime this week and take a couple photos
alex
