  • Dot Guests: 331
Author Topic: CF2 camper, full metal repair and respray with some other things too.  (Read 60463 times)
Offline suterman
Re: CF2 camper, full metal repair and respray with some other things too.
« Reply #30 on: March 11, 2010, 06:36:35 PM »
Well I got the other rear arch done, Now moving onto the fronts is  a different story. I want the front bumper to be removable so I'm altering/adding to the end caps so the front part of the arch is fixed to them and not the van.
Offline suterman
« Reply #31 on: March 17, 2010, 09:35:12 AM »
Front Arches, bumper endcaps.
I got some thick sheet and cut it to match the outer profile of the bumper endcaps.
Drilled through and fixed the front plate to the endcap.
Alex then tacked both front and rear plates onto the arch and cut off the arch at the top of the endcap.
Now I have to make a plate for the back, top and bottom of each section.
More tomorrow.
Offline suterman
« Reply #32 on: March 18, 2010, 08:17:26 AM »
Did more work on the front today, a lot of scissor/pizza boxes/jigsaw/file work done mostly with my tougne sticking out of the corner of my mouth.
I took it up to Alexes and held things in place while he welded.
They're not perfectly symmetrical  but they both match up with their corresponding panels.
When I arrived at the shop I had a prototype cardboard template for the endcap valance piece but Alex said, "You cant use that template!"
"Why not?" I asked.
"You've used Dr.Oetker Pizza boxes and you need to use Chicago town for that kind of work really" :D
He's a jolly chap.
« Reply #33 on: March 18, 2010, 11:40:41 AM »
keep those pics coming!! doinhg well!
Offline TheArchiTech
« Reply #34 on: March 20, 2010, 08:04:40 PM »
Yeah man that coming up a treat. I am very keen to keep seeing pics. You are showingmine I hope you don;t mind me copying ;D
What made you decide to keep the plastic ends of the bumber and not make new steel ones?
Offline suterman
« Reply #35 on: March 24, 2010, 04:02:24 PM »
What made you decide to keep the plastic ends of the bumper and not make new steel ones?
Copy away mate, I dont mind at all.
I think it would be very hard to make steel endcaps, I am struggling as it is, ;D
Here is the latest. Though progress has stopped for a day or two as I have a nasty cold at the moment.
I've only done this side in steel so far but I've made a template for the other side.
ps. all the gaps between the plastic and metal will be fibreglassed in and filled over.
« Last Edit: March 24, 2010, 04:04:03 PM by suterman »
« Reply #36 on: March 24, 2010, 04:47:27 PM »
have a look at Garry's van he has made the whole side skirts etc from steel. His would be a bit different though as to keep the bottom curve etc like you have looks Orr-Some keep up the good work, and me upto date
Cheers Phil
Offline suterman
« Reply #37 on: March 24, 2010, 05:15:27 PM »
Cheers Phil
OK phil
Where can I find pics of garrys van?
I find this forum difficult to search.
« Reply #38 on: March 24, 2010, 05:25:53 PM »
Try this link
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=11475
His slightly different as his is a mark 1 but still gives the idea
Offline suterman
« Reply #39 on: March 25, 2010, 05:39:55 AM »
Uggh, Ten  hours laying turf today whist trying to shake off that cold the had me in a fever yesterday.
No work doing tonight, Beer and internet for me.
I see what you mean about the bumper.
I dont think it would suit this van, As I'm keeping everything else stock. I've kind of been through this before I wanted a "rolled pan" on the back of my 240 as I like the shaved look but, I only got as far as stripping off all the trim and rear bumper trim (to cut out rust on the tailgate slam panel) I think I was going to take the front bumper off that and put a flat front on it. But the practicalities of running  a car with no bumpers?
This is what I ended up with.
1990 Volvo 240 estate.  nicely sorted 2.3 turbo conversion, Rebuilt 2.3  block and head T3 turbo, Manual boost controller with boost almost doubled) Bilstein HD shocks and -40mm springs, polybushed all round, 16 wheels with 225/50/16 tyres ((it was a hoot I once over took a DB9 at 120 mph he bottled it at about 110)))
 but looked like a shed
Anyway......................
I've drifted off.
