  • Dot Guests: 314
Author Topic: Whats the auto  (Read 3257 times)
Whats the auto
« on: November 22, 2009, 05:43:08 PM »
The wreck that I bought a while ago came with some kind of holden 6 with an auto. I'm wondering if for the time being I should put the auto in my van. But I don't know anything about holden stuff  ???
Any way of telling what the transmission is and if it will bolt to my 173?
Thanks
Re: Whats the auto
« Reply #1 on: November 22, 2009, 07:42:42 PM »
if it came off a holden 6 then it will fit on a holden 6..
Re: Whats the auto
« Reply #2 on: November 22, 2009, 08:20:09 PM »
Well thats easy then :)
Offline matty
Re: Whats the auto
« Reply #3 on: November 23, 2009, 12:37:49 AM »
from what i hear, the hard part is getting the shifter soughted if you dont have the original shifter and an early trimatic box.
 the early trimatic box's (pre commodore) shifted from the right (passanger side), commodore box's from the left.
you will all so need the wiring soughted, you will need to light up the little panel that tells you what gear your in and
you'll all so need inhibitor switch working (the thing that stops it starting in forward gears and reverse).
Offline JOE RYAN
Re: Whats the auto
« Reply #4 on: November 23, 2009, 08:47:40 PM »
I am the guy you got the petrol tank off I have done a fair bit of gearbox, diff swapping etc, if you want to talk re gearbox call me on 0418721605
Joe
Re: Whats the auto
« Reply #5 on: November 24, 2009, 08:31:44 AM »
your right matty:) i once spent 6 hours getting my shifter sorted:(  mind you i did want it to
1. look like a manual
2. be totally the opposite way so i could use it as a racing shifter where 1st is fully forward, 2nd then 3rd.
still shouldnt have taken that long thou lol.
Re: Whats the auto
« Reply #6 on: November 24, 2009, 10:07:12 AM »
Thanks guys.
Joe, If I end up wanting to fit the auto I might give you a call. At this stage I'll stick with the manual.
