  • Dot Guests: 270
Author Topic: Wanted frond end rubber bushes  (Read 3265 times)
Offline LWB MICHAEL
  • probationary
« on: November 02, 2009, 10:20:17 PM »
Hello. I am trying to find upper and lower control arm rubber bushes and cross member to body RUBBER bushes
I have found polyurethane bushes with and without an outer steel collar but am concerned the road noise will travel thru .I am running light truck tires.
May the Bedforce be with you
Offline LS120
Re: Wanted frond end rubber bushes
« Reply #1 on: November 03, 2009, 04:26:39 AM »
go to www.pedders.com.au i think. they doo most & rear gas shocks also.
« Reply #2 on: November 03, 2009, 07:01:17 AM »
Try contacting Joel in NZ. He has put polyurethane throughout (so have i) but his van is running (mines not!)- he should be able to give you the heads up on road noise.
Mezz
Offline Joe
« Reply #3 on: November 03, 2009, 09:47:17 PM »
There is these on ebay..
not rubber though ..
and sounds like a new take on urethane ..
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=190346316156&ssPageName=ADME:B:SS:AU:1123
There is always a way .. you just gotta find it!
Offline Worzel
« Reply #4 on: November 05, 2009, 01:33:45 PM »
I've got polyurethane (or whatever the red ones are) throughout the front and road noise isn't bad at all.
Something on the floor would probably help too  :D
Taking off the mags and going to one ton rims with LT tyres made it heaps quieter and the steering lighter
« Last Edit: November 05, 2009, 01:35:46 PM by Worzel »
