  • Dot Guests: 75
Author Topic: holden 202 an 3speed, whats the easyest to put in place of it?  (Read 5661 times)
Re: holden 202 an 3speed, whats the easyest to put in place of it?
« Reply #10 on: October 23, 2009, 10:05:17 AM »
ive got a 3.5 ratio with a turbo 700 auto overdrive box and if i wound this van up it would be doing 4,000 at 200kms. less than the amount of revs a standard beddy would do at 90kms. pretty cool eh..
i herd last night from a bloke 86kms is the most economical speed to travel at. for every 10km over than its the equiverlant of carrying 1 extra ton of weight. so at 200kms it would be like carrying 11.4 ton. wow.
he says this is the case with all vehicles, althou it must make a difference how high it is and sleak.
Offline matty
« Reply #11 on: October 23, 2009, 03:21:25 PM »
I'm not expert on the matter but that statment just doesnt sound right, there is way to many variables.
« Reply #12 on: October 23, 2009, 04:34:30 PM »
Ben with that set up try putting the standard diff ratio back in, with the overdive you will still have a great top end but>>>>>>>>>> down low it would feel like you have rocket bostters ;D
« Reply #13 on: October 23, 2009, 08:29:43 PM »
no thanks bas i enjoy getting 5 kms to the litre lol,
lol, im not expert either  but thats what he said:) he also said try it yourself, sit your car at 86, watch where your foot sits on accelerator, now speed up to 100 and see how much more it sits down, heaps more apparently??
now the bloke i was talking to i did meet on the side of the road and he was driving a toyota coaster camper, if that gives him any credibility or not lol..
« Reply #14 on: October 26, 2009, 07:32:58 AM »
Ben, think you will find you will get better km's as the motor does not have to work as hard. :D
« Reply #15 on: October 26, 2009, 07:48:43 AM »
ya recon?? bas?
well actually i dont use electric lockup cause its laboring a bit too much.
but its a bit too much work for me to put a standard diff back in to go to 5:2 ratio. althou id be able to tow a house up a tree and turn the tree into a tree house. hmmmm
gary white
« Reply #16 on: October 26, 2009, 07:28:38 PM »
ben, if your not using your o/drive and your not carrying a lot of weight you aren't gaining anything by having o/d. baz is right your revs would be around 2600 at 100 kph probably a more efficient area fuelwise and the t700 has a better ratio spread.Unless you've got gobs of power your overgeared.I have dually with 3.5 and t700 at 3.5 ton and will probably have to go back to 4.45 standard.
« Reply #17 on: October 27, 2009, 07:16:21 AM »
i am using the o/drive i just dont use the lockup which gives you another 500 less revs at 100, i plan on putting the hot 400chev back in this van once i get around to fixing the motor so once i do that it will be perfect ratios.
with the overdrive the van sits about 2600 revs, with lockup about 2100. without the overdrive 3,500revs
« Last Edit: October 27, 2009, 07:18:20 AM by ben »
