  • Dot Guests: 319
Author Topic: holden 202 an 3speed, whats the easyest to put in place of it?  (Read 7152 times)
Offline Smartalec
« on: October 22, 2009, 05:16:45 PM »
a celica 5speed, or an aussie 4 speed.
as i dont know much, but love the learning along the way.
something to unbolt an bolt up would be great.. even if i had to cut a new hole in the floor for it..
please help..
the reason i suggested the above, as i herd they were easy?
otherwise anyone fancy the job in SA..lol
Re: holden 202 an 3speed, whats the easyest to put in place of it?
« Reply #1 on: October 22, 2009, 06:01:18 PM »
the aussie 4 speed is a bolt up fit, to where a 3 speed was, with the 5 speed has a diffrent tail shaft, clutch, bell housing and more.....
on another note, the 5 speed is an overdrive, were as the 4 speed is 1 to 1 top gear...
Offline Marky
« Reply #2 on: October 22, 2009, 07:39:54 PM »
I started with
a 3 speed box...
easily changed it for
a 4 speed box
then
changed it for a Celica 5 speed box...which as mentioned is a lot more work...but well worth it!!
i reckon  a overdrive pays for itself in the petrol u save ..
Creative Media Producer
Offline Smartalec
« Reply #3 on: October 22, 2009, 08:17:02 PM »
going from 3 speed to 4 speed would meen i would save petrol an go the speed limit on the hiways  ;D
is that the M20 or M21 im seeing a couple of different types on ebay
« Reply #4 on: October 22, 2009, 08:55:29 PM »
The 4 speed is a pretty good option if you mostly do stop start driving, so long as your diff is a highway diff.
I think its the M21 that has a taller 1st gear otherwise they are much the same.
« Reply #5 on: October 22, 2009, 10:05:03 PM »
it sounds like you need the 5 speed, 3 and 4 do exactly the same thing in top gear... or you could change the diff to highway gears, that could help you get to the speed limit
Offline Marky
« Reply #6 on: October 23, 2009, 06:52:52 AM »
My 4 speed box is for sale ..complete with flywheel,shifter...& 6 month old clutch n pressure plate.. PM if ur interested
Offline Smartalec
« Reply #7 on: October 23, 2009, 08:28:48 AM »
so if i changed from a 3 to a 4, does that meen i can then go 110kms instead of the boring 80kms, i can do 110kms now but it use's like twice the amount of fuel, an the motor wines like hell
NSW bit of a drive - but if you put it in. my miss's likes the idea of a 25hr country drive (dont know if i do tho..lol)
« Reply #8 on: October 23, 2009, 08:34:32 AM »
Did you think about swapping the diff instead. That's the actual problem with the high revs. That will give you the biggest improvement.
« Reply #9 on: October 23, 2009, 09:33:47 AM »
Sounds like you have the high ratio diff still (4:1) the highway diffs run around the 3:1 so as RT says a diff change may be a better option, combine the 4 speed box and you would have a good setup.
