  • Dot Guests: 280
Author Topic: Wiper blade arms  (Read 3043 times)
Wiper blade arms
« on: October 15, 2009, 04:08:19 PM »
Does, anyone on here know if there are any other wiper blade arms the fit the Bedford, that can take a better rubber blade. Cheers
Offline LS120
Re: Wiper blade arms
« Reply #1 on: October 15, 2009, 05:34:57 PM »
i put some dual blade inserts into mine & work fine.
you can get them from supercheap auto..
« Reply #2 on: October 16, 2009, 04:56:23 AM »
I've asked this question before with no results.
I've had a bit of a nosey around when I'm at places like the wreckers as I want to replace mine. The main reason is that the little plastic covers that sit over the mounting hole have long since broken off. Really the only ones that appear to be suitable are the ones off of Jap vans as they are designed to work on a windscreen that sits at roughly the same angle as the CF as well as being mounted on the same plane just below the bottom of the windscreen. It's just the mounting spline that I think is going to be a problem.
That's about as far as I've got as my windscreen is currently out. When it goes back in I'll do something more serious about it but if you find something in the meantime I'd love to know.
