  • Dot Guests: 378
Author Topic: just in case someone knows stuff about autos??  (Read 4546 times)
« on: September 29, 2009, 07:43:46 PM »
tranz working sweet for a few weeks, then started giving me greif, sortof a bit tempermental, where it would not change gears until i got to 4,000 revs in 1st, second 3,500 3rd, 3,200 by that stage im doing like 110kms!
i could get it to work at first by putting more fluid in it, now that doesnt work??
now i pulled the old filter out put in a new one, tranz started working again for a day, maybe 20kms, then back to not changing properly,
here is a post off old holden
Hi all,
I have a HQ Monaro with 307 engine and turbo 700 tranny. I took it for a spin a couple of days ago just up and down the freeway, one bit of hard acceleration and when I was a block from home I found I'm stuck in first gear. Transmission fluid is OK, can't find anything that's fallen off/come loose but I'm open to clues please. Won't change up using the shifter manually either. Park, reverse, neutral are OK, D gets first.
Car had been sitting idle for over a month hence the drive on the freeway, reco'd box should be good?
Any ideas??
Thanks, Rick.
Comment viewing options
Select your preferred way to display the comments and click "Save settings" to activate your changes.
check your vacume module on
Submitted by a Holden Fan on Fri, 05/06/2009 - 00:13.
check your vacume module on the trans my trimatic done the same thing
    * reply
this could be a couple of
Submitted by a Holden Fan on Fri, 05/06/2009 - 01:58.
this could be a couple of things. either your inhibitor switch i faulty or stuffed. or something wrong with your valve body. probably stuck valve or broken wire. i have built many of these boxes. they are called a 4L60E gearbox.
    * reply
T700 box
Submitted by 88ROADSTER on Fri, 05/06/2009 - 02:52.
I had a problem with a Commodore.A switch was sticking inside the auto and the gearbox went into a fail safe mode meaning that it gives you a forwood and a reverse gear so you can still move it.
Phil.
    * reply
you said its reco? take it
Submitted by davehqprem on Sat, 06/06/2009 - 03:29.
you said its reco? take it back straight away.if you tamper with it you may void any warranty.
    * reply
vn v6 auto box
Submitted by a Holden Fan on Mon, 29/06/2009 - 07:37.
hi guys i need to hold 1st gear in vn auto box so it wont change into second at any rev or speed please let me know its kickdown cable cheers steve
[/color]
should i look for a stuck valve or a broken wire?
i have a dvd on the 4L60E about to go find it, then skip tot he troubleshooting section lol
any help would be helpful
Offline cfjeff
Re: just in case someone knows stuff about autos??
« Reply #1 on: September 29, 2009, 09:13:09 PM »
Gidday ben
Don't know if this will help but I had a similar problem with my th400 trans in my panelvan. Mine stuck in low gear and wouldn't change up. took it to the trans shop where they pulled it down and found that a circlip that retains the servo piston had broke dropping the piston and in the process gouging the housing and requiring me to replace the trans casting. hey quoted my $2500 to rebiuld the trans once i get them another trans body. As I was low on funds I went to the wreckers and bought another trans for $400 and put it in. It was supposed to be a good trans that came out of the wreckers old drag car. The problem I then had with that trans was that it would rev out a long time and quite high revs before changing up, then it would cruise along ok. All good except when slowing down to take a corner it would change down too far to first and rev its tit off when you applied the gas again.
 back to the trans shop again for advice, turns out this trans had been shift kitted to skip 2nd all together hence the prob, good for racing but no good for street. Went back to the wreckers and swapped for another trans out of a holden and still going today.
 Don't know if this is of any help, just thought I'd share in case any is of use to you.
 As you have a th700 trans there is a electric solenoid in these trans's that locks up the tourque converter for overdrive, and I've heard that if these are not hooked up right then it can stuff your trans if you drive them.
 Suggest you try ringing a trans shop to get some advice, at least that should be free, coz its very expensive to get a trans rebuilt, or it is here in NZ.
Cheers Jeff
Just customize it!
« Reply #2 on: September 29, 2009, 09:21:42 PM »
hoy ben, that lock out for 4th might be your problem  ;) gotta better idea I'll swap my trusty 253 and 4 speed for that flash motor and box in your flash new van  ;D
« Reply #3 on: September 30, 2009, 07:50:50 AM »
thanks jeff,
and thanks eddy but no thanks. i dont want to burden you with my problems:(
« Reply #4 on: September 30, 2009, 02:09:25 PM »
all fixed!!!!!!!!!!!
seems like it was a sticking valve inside the trany,
to fx it i used some stop leak lubricating trany stuff..
now its working like a dream!!!!
« Reply #5 on: September 30, 2009, 06:01:37 PM »
woo hoo good one little beddie brother !!
« Reply #6 on: October 02, 2009, 01:28:12 AM »
well done ben, just seen ur post , call us for a chat over the w/end if u rememba!
« Reply #7 on: October 07, 2009, 03:40:47 PM »
raining at the moment so no reception, will call ya later dano!!
