  • Dot Guests: 70
Royal Bedford by wendyh
Author Topic: Rim PCD  (Read 6414 times)
hammers_spanners
Rim PCD
« on: August 07, 2008, 07:13:14 PM »
Gday All does anyone know the PCD of a CF and if th single and duels are the same?
Re: Rim PCD
« Reply #1 on: August 07, 2008, 10:01:59 PM »
i might if i knew what PCD was hammers!!
Re: Rim PCD
« Reply #2 on: August 07, 2008, 10:20:48 PM »
Pitch circle diameter. ie the stud pattern.
http://en.wikipedia.org/wiki/Pitch_Circle_Diameter#Bolt_circle
Re: Rim PCD
« Reply #3 on: August 08, 2008, 08:26:45 PM »
5x152................ The dual wheel vans have six thicker studs, but don't know the PCD for them.
I have a couple of dual wheels in the shed if you want me to measure them.
« Last Edit: August 08, 2008, 08:28:46 PM by Jeff »
Re: Rim PCD
« Reply #4 on: August 09, 2008, 10:53:04 PM »
how do you measure the PCD?
hammers_spanners
Re: Rim PCD
« Reply #5 on: August 09, 2008, 11:36:30 PM »
Jeff its ok many thanks
Ben measure from 1 stud to the next from the center to center
Re: Rim PCD
« Reply #6 on: August 09, 2008, 11:51:35 PM »
Not exactly. See the following link: http://www.gomog.com/allmorgan/wheeloffset.html
Re: Rim PCD
« Reply #7 on: August 10, 2008, 08:34:15 AM »
will do some measurements this afternoon..
cheers for that shaneJ
Re: Rim PCD
« Reply #8 on: August 10, 2008, 10:05:42 AM »
No worries mate. The more information we have on here the better.
Re: Rim PCD
« Reply #9 on: August 10, 2008, 02:36:51 PM »
ok so 90mm inbetween 2 studs.. / 0.5878
= 153.113303mm
that make sense??
