  • Dot Guests: 380
Author Topic: Confused New Member  (Read 12235 times)
Re: Confused New Member
« Reply #20 on: September 30, 2009, 02:02:58 PM »
Or take a few leafs out of the springs  ::)
yeah could do that , then it would handle like a wet sponge ::)
disasemble my suspension to compensate for crap roads?
no thanx
« Last Edit: September 30, 2009, 02:06:42 PM by marty »
« Reply #21 on: September 30, 2009, 02:22:34 PM »
i wouldnt say the body is particlarly strong.  bu i would say id prefer to be in the beddy in an accident than a little new car, tin foil!
« Reply #22 on: October 02, 2009, 01:49:29 AM »
welcome monkyman, there is so much info/help on here ,you will benifit so much just by checking out the forum/topics you desire,everything is in there, beddies are resonably easy to work on IF YOU KNOW HOW , which is why we're here.....
check ur potential van for a good body as poss(gutters mainly, inside and out), disc brake front end , stud pattern same front and rear, take a jack and check each side(front end) for any serious wear. other than that you might be looking at a virgin van which can also be a good thing.(depends what you want) if its a good deal go for it , if it dont work sell it? havea beer , get another one... beer or beddie  ;)....dan
Another query about the beddy for you folks:
I mentioned that I was going to buy one and was told by a friend that the bodies are weak and suspension is unreliable. Could anyone tell me things I should look for when buying and what the negatives would be overall?
