  • Dot Guests: 329
Author Topic: rear and side door stays/stops  (Read 7268 times)
Offline heysie
  • probationary
« on: September 13, 2009, 12:58:58 PM »
g'day all,
new to this forum and must say some really nice bedfords around the place, top job! currently in the process of restoring a 74 cf350 and have discovered that the rear and side doors swing back too far and threaten to damage the body of the car when the doors touch. Is there any mods or stock door stays that i can install to prevent this happening? Did the original bedfords have a system to stop this? any info appreciated, cheers!!!
Re: rear and side door stays/stops
« Reply #1 on: September 13, 2009, 03:37:20 PM »
welcome bro!
from what i see the side doors did have a thingy that popped intot a rubber thingy but you cant get them any more anywhere. and if you do find one they are perished:(
best think i recon is to have an old seat belt cut up and pop riveted or something similar to the door and pillar to restrict the door(s)
Offline hunterbynature
« Reply #2 on: September 13, 2009, 04:21:18 PM »
« Last Edit: September 13, 2009, 04:46:32 PM by hunterbynature »
The Cheeky Kiwi
« Reply #3 on: September 13, 2009, 07:21:03 PM »
wow never see them here in aus!
« Reply #4 on: September 13, 2009, 09:30:37 PM »
The rear doors are meant to have little spring steel things that hold the catches in position so that the doors cant open all the way out.
Offline heysie
  • probationary
« Reply #5 on: September 18, 2009, 01:29:31 PM »
ah yes i think i know what you guys mean, anyone know of anywhere i can find these catches and things?
« Reply #6 on: September 19, 2009, 05:47:07 AM »
barn doors came with 2 types of catches. one was a pin throw system (early models think) and the other just 4 catches.
which one you got?
« Reply #7 on: September 19, 2009, 07:34:36 AM »
which one you got?
I think thats the problem
he don't got!
he has a 74 cf350
« Reply #8 on: September 19, 2009, 03:21:59 PM »
yeh but i need to know which ones he should have lol.. i suppose its a bit hard to tell hey.
Offline Worzel
« Reply #9 on: September 19, 2009, 07:39:42 PM »
is there a simple mod?
the back doors don't stay closed (broken/welded hinges don't help though :D)
i think most of the problem is that the doors slip lower, so the top catch pops when the van twists slightly
« Last Edit: September 19, 2009, 07:41:45 PM by Worzel »
