  • Dot Guests: 321
Author Topic: Boss kit  (Read 6161 times)
Boss kit
« on: September 12, 2009, 01:15:43 PM »
For us NZ's, just thought I would post this, got a Boss Kit sent from www.accessoriesonline.com.au no problems, delt with a guy called Stuart, good contact updates and sending of goods. I don't want a small sports S wheel on my van due to the size, but this allows me to have a good choice of a factory S wheel from another model. Cost $84.00 all up. Cheers Bas.
Offline hunterbynature
Re: Boss kit
« Reply #1 on: September 12, 2009, 03:10:36 PM »
that would be 84.00 bucks aussie dollar would it bas?
The Cheeky Kiwi
Re: Boss kit
« Reply #2 on: September 12, 2009, 04:23:19 PM »
Sorry Stevo, yes would have been $84.00 AUS, as used paypal, talked to one of the guys at Wottons in NZ and they said the last ones they sold some 1-2 years ago went for $85.00 so I guess if you can't get them here this is the next best thing, O came with the center horn as well, hooked it up all fits and works well.
« Last Edit: September 12, 2009, 04:42:39 PM by Bas NZ »
Re: Boss kit
« Reply #3 on: September 12, 2009, 04:41:50 PM »
sounds good bas, i better order myself one ;D
The Cheeky Kiwi
Re: Boss kit
« Reply #4 on: September 12, 2009, 08:09:07 PM »
What sort of standard wheels can you run Baz ?? a larger wheel would mean not having to rely on the ArmStrong power assisted steering.
« Last Edit: September 13, 2009, 08:15:57 AM by Warren »
Re: Boss kit
« Reply #5 on: September 13, 2009, 08:00:32 AM »
you know what i would prefer.. to change the ratio of the steering rack. but im pretty sure thats not an easy task:(
Re: Boss kit
« Reply #6 on: September 13, 2009, 11:25:26 AM »
I thought a boss kit only allowed you to fit other aftermarket steering wheels. Factory ones you are stuck with what you get with the wheel ???.
Offline matty
Re: Boss kit
« Reply #7 on: September 13, 2009, 11:38:57 AM »
when it comes to steering wheels the bigger the better.
it gives you some where to rest the newspaper while your driving.  :)
Re: Boss kit
« Reply #8 on: September 13, 2009, 03:40:34 PM »
if you strip the orig wheel down, make a bigger wheel if your that keen, a re trim it!
Re: Boss kit
« Reply #9 on: September 13, 2009, 05:37:17 PM »
Will let you know what wheel I use,If you want to use a factory wheel its no problem, yes you have to re -drill the holes to match the boss kit but this is easy, took the wheel of our Delica 4x4 this morning and re-driled it fittered purrrrrrfit, hay but get this the wife came out to use the van while I had the s- wheel off and ask me if I knew where it went, I said someone must have taken it, her answer was SH...t, ok shes a Blondie, its back on now, but it looked better on the Beddie. ;D
« Last Edit: September 13, 2009, 05:39:55 PM by Bas NZ »
