  • Dot Guests: 156
Author Topic: will this fit  (Read 3655 times)
Offline grandad
will this fit
« on: September 12, 2009, 09:02:35 AM »
Re: will this fit
« Reply #1 on: September 12, 2009, 09:17:43 AM »
it will fit.
the bloke doesnt know what ratio it is.. so you could be buying anything??
it looks good. especially for 99c:)
i dont think its standard centre. even thou the bloke says its a standard diff.
« Last Edit: September 12, 2009, 09:21:36 AM by ben »
Re: will this fit
« Reply #2 on: September 12, 2009, 12:48:50 PM »
freight would be a killer thou to adelaide!!!! ive never looked at getting a diff freighted but it cant be cheap!!
Offline grandad
Re: will this fit
« Reply #3 on: September 12, 2009, 03:17:05 PM »
gettting price on frieght monday was hoping there was a BUGA mate close to this place that could check the ratio if not and it goes cheap salisbury is ezer to get other ratios than a bedford one
Re: will this fit
« Reply #4 on: September 12, 2009, 03:25:06 PM »
its not a salbusy diff.. its a salsbury type diff.. as aposed to a banjo type diff that unbolts from the front of the housing..
and ive been quoted 600 - 1000 to change over ratios on salsbury type diffs by diff specialists..
people say you can do it yourself if you swap everything over from one diff to the next.. but i have not given it a go yet.
Offline matty
Re: will this fit
« Reply #5 on: September 18, 2009, 03:45:04 AM »
this diff In question here is a chevy 12 bolt out of an impala, so i've been told (its the same as mine).
I would of mentioned something sooner but I didnt want to drive the price up, not that it mattered
cause I could make it to computer in time.
if it was someone on here that won this diff and didnt want the sway bar I would be more then happy to
make a deal with you.
Cheers Matty
Re: will this fit
« Reply #6 on: September 18, 2009, 07:01:24 AM »
i won the diff.. i knew it was a 12bolt but wasnt sure if it was modifyed for bedford width or not? should have probably found out the width of it. but its perfect ratio!! 3.54
ill pm you.
« Last Edit: September 18, 2009, 07:05:13 AM by ben »
