  • Dot Guests: 162
Author Topic: Soad Blasted Beddy  (Read 12856 times)
Re: Soad Blasted Beddy
« Reply #10 on: October 07, 2009, 05:29:32 PM »
bargain make sure he dosnt warp it or use a heavy media.
Offline hunterbynature
« Reply #11 on: October 07, 2009, 05:45:32 PM »
PERSONALLY i wouldn't get the door skins,back guards etc or any really large panels done, just stick to the lower parts and underneath etc, floor, firewall, just the stuff that has plenty of meat. big panels a no-no, as craig said   warpage  is the word  ;D
The Cheeky Kiwi
« Reply #12 on: October 07, 2009, 07:33:39 PM »
i agree - did my homework on this one and would never go the sandblast on a beddie - panels waaaaayyyyyy too big and will easily distort.
« Reply #13 on: October 07, 2009, 07:42:50 PM »
couldnt think of much worse, paying good money for it to come back in worse shape than it went!!
Offline waikatostocky
« Reply #14 on: October 07, 2009, 08:11:41 PM »
low air preasure and a medium soda it should be all good. Have seen some faily big panels done here and they came out all good ;D
be safe out there
« Reply #15 on: October 07, 2009, 08:20:30 PM »
alot depends on the sandblaster a smaller operation is always better (mostly) cause they are not so industrial minded I had the chevy glass bead blasted and it was great.
Offline Kirk
« Reply #16 on: October 08, 2009, 01:26:56 PM »
I was worried, im sure the guy that owned it last did sandblast it (at home himself) and i think thats how it got the little pin holes in the gutter area (not in the drain part but along the side of roof).
I do think it needs to fully go back to bare metal after sitting in the rain with windows open for 3mnths tho.....now mine is in primer, do you think the soda blast could be cheaper, and if i remember correctly from my research, sodablasting leaves a protective film on the metal.....is that correct (obviously not a long term defence).
« Reply #17 on: October 08, 2009, 02:01:52 PM »
iv'e got a portable sandblaster that i use glass beads in so gonna use that with a combination of paint stripper first and then blast it clean, but only on the solids bits of the bedy, will hand strip the larger panels by hand ;D
The Cheeky Kiwi
Offline strez
« Reply #18 on: October 08, 2009, 06:17:10 PM »
soda blast and sand blast will give you two different types of results . soda blast strips paint and light surface rust , sand blast strips every thing . sand blasting big panels can be done with out warping it all depends on the operator . had an old chevy at my work soda blasted had bad surface rust had to get it sandblasted as well to get rid of it. lucky i didn`t have to pay for it  :D
« Reply #19 on: October 10, 2009, 08:17:03 PM »
hey welcome back strez:) havent seen you on here for a while!
