  • Dot Guests: 287
Author Topic: Disc Brakes  (Read 21340 times)
Re: Disc Brakes
« Reply #20 on: September 09, 2009, 02:00:38 PM »
Oh no not another one in the drive Craig!! :-[ :-\
who me? na .........  maybe ....later.... ;)
Offline Shazbot
Re: Disc Brakes
« Reply #21 on: September 09, 2009, 02:56:47 PM »
hey shazbot intrested in a social day ? guys are starting to pm me for a date thinking about having another perth bugga day maybe when the weather warms up a bit and as we have a few southern guys might be good to head down your way?
You just want to see how many vans you can actually park on Shazbot's front lawn.  :P
I recommend that Shazbot counts her vans again after you guys have left just in case one mysteriously walks...  ;D ;D
I am told that there is room for many more,,,as long as they are parked the right way! hehehe ;D
What you looking at?
Offline weasil
Re: Disc Brakes
« Reply #22 on: September 09, 2009, 03:58:40 PM »
Howdy ,I have a van and my son has one
disc brakes got to luvem,I have done CRS kit and HQ discs but settled for hopper stoppers .we talked to peter at hopper stoppers and he made the first bedford kit in OZ.Machined the  hubs to fit bedford stubs through to all hardware ,lines,with 300mm rotors and 4 pot calipers they are sic .plug and play is the way to go
weasil ;)
Offline hunterbynature
Re: Disc Brakes
« Reply #23 on: September 09, 2009, 04:33:09 PM »
http://www.hoppers.com.au/index.html
theres been alot of interest in buga about doing brake upgrades on our beddies, this site, hoppers will tell you everthing you need to no about brakes and how they work, so read up beddie brothers, very interesting reading, they give you a really good undrstanding how it all works ;D
« Last Edit: September 09, 2009, 04:50:32 PM by hunterbynature »
The Cheeky Kiwi
Re: Disc Brakes
« Reply #24 on: September 09, 2009, 06:35:52 PM »
now this has to be a dangerous one eh?
hehe
« Last Edit: September 09, 2009, 07:47:30 PM by ben »
Re: Disc Brakes
« Reply #25 on: September 09, 2009, 07:08:38 PM »
hey shazbot is this one of the dangerous things your were talking about?
BEN I SHOULD SMACK YOUR BUM!!
Re: Disc Brakes
« Reply #26 on: September 09, 2009, 07:10:04 PM »
i wouldnt like havin disks on my van with turned down stubs.
even if their supposed to be rehardened.
just my opinion though.
« Last Edit: September 09, 2009, 08:10:14 PM by marty »
Re: Disc Brakes
« Reply #27 on: September 09, 2009, 08:06:56 PM »
sorry everyone that was bad taste. and im gunna make up some proper stands now cause my dodgey stands are dangerous. and i would never get underneath them thou.
sorry again
from silly ben
Re: Disc Brakes
« Reply #28 on: September 10, 2009, 12:26:15 PM »
(email i got back from hunterbynature,s  brake mod link. after asking if the stub can be machined.)
Marty
Yes we do a Bedford brake upgrade, it needs minimum 15 inch wheels in Holden or Ford pattern. Cannot do original Bedford pattern as the PCD is too big.
Kits are $1350 with smooth rotors, $1450 slotted rotors, $1500 drilled and slotted. This uses original Bedford wheel bearings etc and bolts to standard unmodified stub axle.
Kit includes conversion hubs, bearings seals grease caps, DBA rotors off BA ford drilled from blanks for Holden pattern, PBR twin piston calipers off AU3 Ford, all mounting brackets spacers bolts and hoses.
You also need a 1 inch tandem master and adapter plate which we have at $320. You will then need to make new lines from the chassis to the master cylinder as the fittings are different.
We have seen the older method of machining the stub axle down to take Holden or Ford wheel bearings but I have been told of stub axles breaking and the DOTARS rules specifically say reducing stub axle diameter is forbidden so we won’t do it.
Peter Koning
« Last Edit: September 10, 2009, 01:42:42 PM by marty »
Offline Rothu
Re: Disc Brakes
« Reply #29 on: September 10, 2009, 01:43:46 PM »
Thanks Marty, that should make it crystal clear!
