  • Dot Guests: 258
Author Topic: ROTHU????? 3 Core radiator  (Read 3046 times)
Offline ggas250
« on: August 19, 2009, 08:38:50 PM »
 Hey Rothu you mentioned you fitted the larger commodore 3 core radiator to your beddy. What model was it from and was it a 6 or a V8.
Cheers Wayne
Offline Rothu
Re: ROTHU????? 3 Core radiator
« Reply #1 on: August 20, 2009, 10:40:56 AM »
It was a 3 core cross flow from a 6 cylinder later model commodore. I originally got a 2 core cross flow from Centre Road Wreckers which worked fine even through the summer, and I've still got that if you want it.
The 3 core I got off ebay from a guy who was wrecking a commodore. Dunno which one. It's basically brand new.
It just fits in at 670mm wide. Make sure the hose outlets are on the right sides!
I had to separate the wire loom to move it up out of the way of the radiator.
I also cut a section of the plate that is in front of the radiator which is the entire reason for Bedfords overheating.
« Reply #2 on: August 20, 2009, 12:09:12 PM »
another thing you can do it turn the thormostat houseing around so it faces the opposite direction if you have the also.
Offline ggas250
« Reply #3 on: August 20, 2009, 07:33:59 PM »
O.K. how much do you want for the 2 core radiator as mine is shot and has to be replaced anyway?
Cheers Wayne
