  • Dot Guests: 290
Author Topic: wipers question  (Read 15834 times)
Re: wipers question
« Reply #10 on: August 12, 2008, 08:50:52 AM »
yeh thats real good thanks heaps!!! i have a few stuffed motors laying around.. will be very handy thanks
Offline Banksx2
  • Willagee WA
Re: wipers question
« Reply #11 on: June 18, 2011, 03:45:05 PM »
I've just got hold of the wiper motor and amabout to start fitting it as in Rogue's instructions (great work there mate!)
Has anyone got a cheat-sheet on which wire does what or do I do it the good old fashioned way and nut it out?   :)
Garry
Re: wipers question
« Reply #12 on: June 19, 2011, 09:59:17 AM »
Great idea Rouge....Did you notice if there was much wear on any of the rods from the bedford?
Re: wipers question
« Reply #13 on: June 19, 2011, 10:11:27 AM »
Rods? Which part would they be?
Re: wipers question
« Reply #14 on: June 19, 2011, 10:35:56 PM »
The ones that pivot from the wiper motor  ;)
Re: wipers question
« Reply #15 on: June 20, 2011, 06:00:58 AM »
Mine were all fine but then my van is quite a late model and hasn't had a lot of use in the past 15 years.  ;)
Re: wipers question
« Reply #16 on: June 20, 2011, 10:36:57 AM »
:D :D :D :D :D :D :D :D :D :D :D :D
Offline mbasinski
Re: wipers question
« Reply #17 on: June 24, 2011, 07:47:05 PM »
tried getting the motor out. undid eveying but cant get it 2 come out. is the only way 2 get it out is 2 remove the instrument cluster?
Re: wipers question
« Reply #18 on: June 24, 2011, 10:12:55 PM »
is the HQ-WB wiper motor the standard unit on the bedfords, or is mine a modified unit?
Either way, mine runs the HQ-WB wiper motor..
A later model ford would be the go tho ;)
Offline Banksx2
  • Willagee WA
Re: wipers question
« Reply #19 on: June 25, 2011, 10:51:29 AM »
All I did was undo the bolt on the motor tunnel/firewall and the big ringnuts on the wipers themselves. Took a bit of a tap with a soft hammer on the wiper stems to loosen the assembly and out it came.
The wiring still has me stumped though and I can't get the new motor going - no movement at all. It's got me wondering if I've bought an ebay dodgy.
