  • Dot Guests: 198
Author Topic: Indicators  (Read 17936 times)
Offline TomB
Indicators
« on: August 13, 2009, 06:27:12 PM »
As per my previous post (CF Cab Chassis) I am seriously thinking of buying a CF350 cab chassis. It is currently unreg and on a farm. When I drove it around the indicators don't work at all and I immediately thought of the flasher can. I searched around under the dash but couldn't find it.
Anyone know where the flasher can is located?
Offline hunterbynature
Re: Indicators
« Reply #1 on: August 13, 2009, 06:42:55 PM »
take off the rear plastic panel on dash its in there me thinks :D
The Cheeky Kiwi
Re: Indicators
« Reply #2 on: August 14, 2009, 04:42:33 PM »
Look under the dash panel where it supports the steering column, poke your finger up through the opening and you should find the canister  ;)
Offline TomB
Re: Indicators
« Reply #3 on: August 14, 2009, 04:46:13 PM »
Thanks guys, I'll have a look when I'm up there next. I am hoping it's just the flasher can busted or missing as I don't fancy trying hand signals all the way home (about 200kms).
Offline Smartalec
Re: Indicators
« Reply #4 on: August 14, 2009, 04:56:45 PM »
u might find 2 flasher cans in it. one for hazzard an one for indicators
easyest way, get the 2 wires that goto the flasher can , an short them together..
now when you use the indicators they should only stay on..
easyest way i know if its the flasher can or something else test..
once i had to tie 2 pieces of rope to the wipers, one for me to pull (driver), an then one for the miss's to pull them back.
(got us home..)
(never give me rope an say it cant be done..lol)
« Last Edit: August 14, 2009, 05:04:26 PM by Smartalec »
Re: Indicators
« Reply #5 on: August 14, 2009, 05:03:04 PM »
before you go wrenching you neck under the dash looking for the indicator flasher i suggest you check the fuse first  ;D
The Cheeky Kiwi
Offline Smartalec
Re: Indicators
« Reply #6 on: August 14, 2009, 05:07:32 PM »
fuse 2 from the door for hazzard an fuse 5 from the door for the indicators
great thinking hunterbynature why look for the worst when it could be the simplest
Offline TomB
Re: Indicators
« Reply #7 on: August 15, 2009, 05:50:02 PM »
Re the fuses, there doesn't appear to be a proper fuse box. I noticed a bunch of fuses hanging down from under the dash just to the right of the steering column. Just blade fuses with no labels.
Offline Smartalec
Re: Indicators
« Reply #8 on: August 15, 2009, 06:15:24 PM »
pull each one out , one at a time a check to make sure there not blown then replace them back
sounds like a mod or something, mine are all glass fuses
Re: Indicators
« Reply #9 on: August 16, 2009, 08:14:59 AM »
blade fuses are not standard. so its probably a bodge job. 71- 74 beddys didnt come with fuses standard. in my black van i pulled the bodge job out and replaced it with a 76 onward wiring loom. much better..
