  • Dot Guests: 340
Author Topic: Indicators  (Read 17919 times)
Re: Indicators
« Reply #30 on: January 15, 2010, 04:52:45 PM »
Hey Joe, do you have any pics of your mini indicator stalk fitted into your van. Also do you have any data on the stalk, ie: mini model, year, so on.  ???
            George.............
Offline JOE RYAN
Re: Indicators
« Reply #32 on: January 16, 2010, 03:50:25 PM »
George
Your mate Rob the Bedford man a Logan sell new indicators already converted for about $70 but you have to give him your plug for his next conversion
Joe
Re: Indicators
« Reply #33 on: January 17, 2010, 07:56:12 AM »
Thanks joe, I am going out to see rob next weekend, so will ask him about them, have a look. Is there no problem  this site can't solve. yeh  ;D :D ::)
           George..................
Offline Rothu
Re: Indicators
« Reply #34 on: February 23, 2010, 11:20:47 AM »
I've been systematically replacing all frigging crap lucas electrics with Bosch parts. The indicator stalk I've replaced with one from an early falcon, they also used the same one in early ford amubulances. The difference is incredible! I actually have WHITE headlights rather than lame yellow.
Re: Indicators
« Reply #35 on: February 23, 2010, 12:40:37 PM »
camden you should be running relays.. dont trust mr lucas!
Offline Rothu
Re: Indicators
« Reply #36 on: February 23, 2010, 02:40:52 PM »
I'm running relays for just about everything! Everytime I replace a lucas part with bosch, I take a blow-torch to the lucas bit! Mwooooahahahaha!
Offline Jonbongjovi
Re: Indicators
« Reply #37 on: April 29, 2010, 06:47:59 PM »
I can't for the he'll of me get my indicators to flash at the correct speed ... One is way too fast and the other  doesn't actually dim all the way before it flashes again... I've checked all  lamps/ wiring that I can get too and put In a new flasher.... They are doing the same thing regardless of whether the flasher can is in or pulled out... Hazards work fine.... Anybody got any ideas?
Offline cfjeff
Re: Indicators
« Reply #38 on: April 29, 2010, 08:58:23 PM »
Gidday Jon, I don't know what year your van is, mine is a 76 and has 2 flasher cans, 1 for the indicators and 1 for the hazzards. A couple of things to try is unplug the flasher can and make a wire to join both wires of the flasher can together then try the indicators, this will cause the indicators to come on and not flash. This will tell you if the switch and bulbs and bulb earths are all ok. If this test works and the indicators light then the fault lies with the flasher. If not then check for power in the green wire to the flasher can, if this is ok next check the indicator stalk for continuity between the light green with a brown stripe wire and the green red stripe wire when you turn one way and thelight green brown stripe and green white stripe when you turn the other way. Other things to look at are the bulb earth connections, if these are bad or weak then this can cause them to flash fast. All of this is assuming you have factory wiring loom that has not been messed with or colours changed. and also assumes you have 2 pin flasher cans. And is how my 76 factory loom was connected. Remember to look for the second flasher always catches a few out.
Oh and one other thing to check is your hazzard switch, mine used to give me trouble when I switched it off, it wouldn't reconnect the indicators.
Hope this helps
cheers Jeff
Just customize it!
Re: Indicators
« Reply #39 on: April 29, 2010, 09:00:20 PM »
sounds about right:)
