  • Dot Guests: 361
Author Topic: Reco'ed 186 for gas wanted.  (Read 5804 times)
Re: Reco'ed 186 for gas wanted.
« Reply #10 on: August 07, 2009, 08:57:39 PM »
hey warren,
have you tried doing a compression test on the motor you have in there now, there not to expensive
to buy a compression tester and could save you spending on things you dont need. plus its a handy tool to have
especially when dealing with old and second hand motors.
just a thought
Matty
Yeah I have a hand held one - had problems getting it to seal properly on a couple of cylinders, but from memory it was around 140 psi on most of em - might try and do it again.
The thing is its an old unkown engine, I bought a diff and front end and got the motor with it, I've spent quite a bit of time trying to get it running properly were if I had a motor of known condition it could be running by now.
Mezzmo's should be great, straight swap with a known engine, then I can rebuild the other one in my lessure - I get the feeling that the old motor may have burnt valves.
« Reply #11 on: August 07, 2009, 10:23:36 PM »
hey warren bro, I'm available most weekends at the mo. better soon than later coz my gantry is going to a mates for a while, he needs it to engine swap a 1963 chev truck and he works slow as ...... give us a call  ;)
« Reply #12 on: August 08, 2009, 10:54:39 AM »
Thanks Eddy - will call you - but yeah sooner than later is the go - maybe next weekend, Ive got 2 sick munchkins at home at the mo :(
Offline Rothu
« Reply #13 on: August 08, 2009, 03:41:49 PM »
Ah, Rogue, cannot find any "Technical Documents" on site....  ???
The post you did for the brake conversion has a copy of the specified machining required for disk brake conversion but you can't read any of the specs! Can you rescan it so the numbers are legible? Ta.
Also I'm getting a bloody irritating "flutter" in the engine when under load which cleans up when it gets up to 2750 revs. It will also rock and shudder at idle but after 2 minutes settles down to clean.
Have been running it on gas forever, but the engine was (5years ago) recoed with hardened valve seats.
I've checked all the vacuum hoses, replaced brake booster, recoed carby, replaced manifold gasket, compression is equal across all cylinders, plugs fine, electronic dizzy shaft fine, at my wits end!!!
A friend mentioned that holden uses cheap neoprene timing gears that finally give up.
Anyone had this before? Absolutely STUMPED!!
« Last Edit: August 08, 2009, 03:43:29 PM by Rothu »
« Reply #14 on: August 08, 2009, 03:59:10 PM »
AHA!!! Correct! Sorry but it was a dig at Shane our site admin as I've been after this for a while but he seems to be having issues with the downloading side of it.
Shane, can't you set them up like the flyers on the front page?
Rothu, if you pm me your email address I'll send it to you. How's that?
« Last Edit: August 08, 2009, 04:02:29 PM by Rogue Trooper »
