  • Dot Guests: 390
Author Topic: Needing help badly, frount brake locked on  (Read 24226 times)
Offline hunterbynature
Re: Needing help badly, frount brake locked on
« Reply #10 on: July 31, 2009, 04:08:21 PM »
give me a few mins will get back to you
The Cheeky Kiwi
« Reply #11 on: July 31, 2009, 04:10:22 PM »
Have a look here
while it is a rear brake from memory the front is the same (long time since I had drum fronts)
« Last Edit: July 31, 2009, 04:12:06 PM by Warren »
Offline Smartalec
« Reply #12 on: July 31, 2009, 04:15:27 PM »
sorry warren,
 i need frount drum
« Reply #13 on: July 31, 2009, 04:17:12 PM »
theres a rod with a square head on your backing plate turn that
The Cheeky Kiwi
Offline Smartalec
« Reply #14 on: July 31, 2009, 04:19:05 PM »
there's 2 rod thingys each side..
« Reply #15 on: July 31, 2009, 04:21:08 PM »
that correct one for each wheel cylinder, try each one untill its becomes lose, try your front one first if it becomes lose then due the rear one
The Cheeky Kiwi
« Reply #16 on: July 31, 2009, 04:26:18 PM »
i presume that you heve the vehicle jacked up to work on the wheel, dont forget tpo put axle stand under aswell
The Cheeky Kiwi
Offline Smartalec
« Reply #17 on: July 31, 2009, 04:38:43 PM »
u have a backup jack under her as well, an a spare tire at the back to stop the rolling
very very backyard
then things dont wannt turn.. an what way do i force them to turn
i was stupid an just pumped the breaks.. now it's gotten stiff again to turn the wheel hub..
could disconnecting the break line help?
whats the problem? an how much would it cost profeshionaly to fix it?
as light is dimming an i need the var first thing in the morning
« Reply #18 on: July 31, 2009, 04:44:26 PM »
if you turn say your front adjuster can you get any movement out of it?  you shouldn't have to turn it much to get any movement, dont disconnect the brake pipe just undo the bleed valve quickly then tighten again, this may relieve some pressure
The Cheeky Kiwi
Offline Smartalec
« Reply #19 on: July 31, 2009, 04:52:36 PM »
yes i can just adjust them rods an it made it spin better.. not much
 but the hub still not wanting to come off..
