  • Dot Guests: 259
Author Topic: Hinge suggestion for gull wings  (Read 20054 times)
Offline Jeff
Re: Hinge suggestion for gull wings
« Reply #40 on: October 11, 2010, 09:54:00 PM »
Yes. Welcome back Eddy.  ;D
Funny old life.
« Reply #41 on: October 11, 2010, 10:16:05 PM »
WooHoo welcome back buddy
Hope you start posting again
« Reply #42 on: October 12, 2010, 04:51:35 AM »
One thing that hasn't been mentioned - door rubbers
piano hinges are good but don't allow a seal between it, if you do try squeeze the door closed with full rubber in there you will be putting massive amount of pressure on the hinge pin and inturn would break the collars holding the pin (same as any hinge)
so you have to compromise; looks (show cars most often dont use door rubbers) vs practical (piano higes take up the less room) vs weather (dust, water, wind noise ...) ...  maybe use the paino hinge but change the door rubbers to a jappa style
and use stainless steel
The rubber is fine. In fact it's even easier than a standard door rubber. You can buy the flat rubber strip from any rubber supplier. You used to be able to get it from Para before they went west. As the piano hinge doesn't close flush the rubber seal sits in the gap quite nicely and compresses without any dramas over the mounting screw heads.
« Last Edit: October 12, 2010, 04:55:36 AM by Rogue Trooper »
« Reply #43 on: October 12, 2010, 08:40:20 AM »
eddy welcome back!!!!
tryed to call you the other day to see how everyone is but could not get through.
will try again.
« Reply #44 on: October 12, 2010, 08:29:17 PM »
hey thanx all my brothers from many different mothers, or should that read many daughters from different borders? lads from different dads?  uh nuh okay silly billy me .... didnt roam too far away from BUGA, been a long term addiction of beddiemania if you know what I mean, I have been checking the forums regularly but haven't been responding, however this post is interesting as I have spent the past couple of weekends mounting a fibreglass gull wing door to the beddie so thought there is an onus on me to help where I can ......... did travel for 9 weeks up Queensland way towing the caravan been back in Vic for past 3 weeks ... what a frigging adventure, but thats another post topic  ;) not interested in the f/book saga water under the bridge, now I gotta get me a gallery a happening again .....  ;D hey little bennie bro we changed ph details again PM me and I'll pass on the new no. geez bro judging by the activity in the posts have you been busy !!  Beddie on !!!!!!  ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #45 on: October 15, 2010, 08:47:36 AM »
O.K. guys time to think outside the square, when hot rodders are building a rod that came out with a dicky seat and they want to turn it into a boot they are going to need hinges that open "out and away" so your hinge needs to be shaped like the letter J, Hank from Street Rod Services in Rockingham ended up making his own for the rear door on his 1934 Ford Sedan Delivery and it works very well, so Google some hot rod shops to see what they have, I've had some good dealings with Timic Hot Rod Supplies so I would start there
Petrolhead
Offline pickmeup
« Reply #46 on: October 15, 2010, 03:19:57 PM »
Landrover Mk1 rear tailgate hinge! ;)
-Charlie Hutton
« Reply #47 on: October 15, 2010, 06:41:06 PM »
I made the hinges for my gullwing side and back doors, they are a ? shape
Offline hunterbynature
« Reply #48 on: October 15, 2010, 06:44:08 PM »
if ya turned that upside down dave and put another beside it it would be the sameshape as the wifes butt,  PEARSHAPED   haha ;D
The Cheeky Kiwi
