  • Dot Guests: 293
Author Topic: SWB for sale melbourne  (Read 6285 times)
Offline maria
« on: July 14, 2009, 11:20:39 AM »
Hi folks,
sadly she has to go. Have spent thousands on her and now I need some back. I will have a van again one day. Just not possible right now.  :( PHOTOS http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=536.0 AND http://www.buga.com.au/index.php?option=com_gallery2&Itemid=8&g2_itemId=7462 . These are older shots but I don't have a camera today.
Windowless SWB, auto, dual fuel (only gas at the mo, fuel line issue), not original diff (borg warner?), red 202.
$3500 or make an offer. Advertised elsewhere.
New tyres, New bearings, New triple core radiatior with recovery system, New windscreen, Lifters and pushrods replaced at christmas, Head gasket done at christmas, Exhaust headers, Deep dish sports steering wheel, Custom dash, Rubber flares (currently not on), Air horns, New plugs and leads, Kenwood speakers in rear doors.
Body needs to be finished, some work to be done inside. Custom dash needs doing with the body I reckon thou maybe not-depends your asthetic.
Van was roadworthied at christmas. Is registered but selling unreg, no rwc unless you want to do one quickly. Don't know what it needs for this. Ben did the bodywork and a long list of things for roadworthy:
-weld up seat base
-fit bolts to seat base (missing)
-move gas compliance plate (wrong spot)
-fit bolts to wishbone L+R (missing)
-fix auto cooler lines rubbing
-Fix vacum lines rubbing
-Fit washer to auto linkage (missing)
-Fix speedo cable rubbing
-Fit another bolt to engine mount(missing)
-Cut off old exhst mounts + loose brackets
-Fix rear shocker mounts (ended up welding)
-Fix rear wiring loom rubbing
-Replace rear springs, clean up second hand ones, Paint second hand ones ones
-insulate brake lines (rubbing)
-tighten up steering rack (slop)
-Replace gas valve twice
-Replace lower right ball joint with second hand good one
-Dismantle all wheels for brakes, take photos for roadworthy
-Replace bolt on spring (not sure what this was)
-Fit washers o tail shaft bolts (missing)
-Fit tie rod end pins (missing)
-Adjust bonnet so not scrubbing out windscreen wipers
-Change axels for best bearings i had at time
-change axels for new bearings
-Fit new temp guage
-Had running on petrol
-Lift up body from Front end to check bolts tight
-swap over gas tank for my indate gas tank
-body work cut + weld all sections on body and front doors (remove of panels and refit)
-side cargo door and bonnet just fibreglass bogged no welding
-Bleed brake system
-Remove and fit second hand rear brake line
Re: SWB for sale melbourne
« Reply #1 on: July 14, 2009, 11:48:19 AM »
What a bummer Maria :'( Well nobody can say that you didnt give it a good go. Dont forget to keep talking to us on this site. Even if you dont have ya beddie ,its always nice to correspond with beddi lovers. :) Best of luck with whatever your planning ;D cheers..johnno
Offline maria
« Reply #2 on: July 14, 2009, 06:57:31 PM »
thanks johnno,
life just does these things sometimes. i will survive.
Offline chum_007
« Reply #3 on: July 14, 2009, 09:04:41 PM »
Hey Maria.
Would very much like to come and have a look if there's any chance.
Where abouts in Melbourne are you located??
Im in Cranbourne.
Thanks.
Offline maria
« Reply #4 on: July 14, 2009, 10:39:20 PM »
Hey Maria.
Im in Cranbourne.
Thanks.
hey chum
van's in fairfield with me. PM me your number and we'll work out a time
« Reply #5 on: July 15, 2009, 12:27:31 AM »
sorry 2 see your selling it maria, i remember how wrapped u were in getting a SWB.
life brings changes sometimes we cant detour around.
best wishes, take care.
regards marty
Offline maria
« Reply #6 on: July 15, 2009, 01:26:29 AM »
thanks marty, really appreciate your support
x
« Reply #7 on: July 15, 2009, 01:37:52 AM »
that's a Shame maria.....was looking forward to and watching your van build project mate you was doing such a great job. I know what your going through (if it's work wise) that is , as there's not much out there and of coarse those that are lucky enough to still be employed are hanging on to their coin, good on em too . chin up mate , all the best  and i'll look forward to ur next Beddie!!! ;D ;D
Offline maria
« Reply #8 on: July 19, 2009, 01:39:54 PM »
thanks dano,
yup, in a bit of a hole. want the van to go to a good home where she will be appreciated.
Offline maria
« Reply #9 on: August 24, 2009, 10:21:50 PM »
still for sale...
