  • Dot Guests: 271
Author Topic: vk efi inlet manifold  (Read 7200 times)
« on: June 28, 2009, 06:30:10 PM »
a friend had one sitting there that he bought but didn't use... it has all parts/tubing/fancy saas filter...
he is also giving me a spare lpg gas tank that he is ripping out of a shorty 40.
so here's the thing.
if i go straight gas using two tanks and this vk efi manifold on will i be getting the added power and economy the friend claims?
im reading a mag that claims in a article that if you use this manifold and put a yella terra gas head and a voodoo gas research cam shaft you can get up to 120 hp at the back wheel (up from the standard 65 a red 202 puts out). im not willing to go that far but the friend claims added hp just from the manifold alone.
he also gave me a vk instrument panel... looks in good condition but i was wondering how much work to wire it up in a beddy?
Re: vk efi inlet manifold
« Reply #1 on: June 28, 2009, 07:43:52 PM »
sounds good if it gives u the extra horsepower but bear in mind that a red 202 has different inlet ports to a blue or black 202. so if the vk has the later model motor u will prob need the head to suit the ports.
just trying to save u some greif.
marty
« Last Edit: June 28, 2009, 10:48:10 PM by marty »
« Reply #2 on: June 28, 2009, 10:19:16 PM »
can you identify its compatibility from this pic?
« Reply #3 on: June 28, 2009, 10:28:59 PM »
cant be 100% sure but looks blue or black.
i think from memory VB RED 202 and VK were BLUE 202
marty
« Last Edit: June 28, 2009, 10:34:34 PM by marty »
« Reply #4 on: June 28, 2009, 10:42:16 PM »
not looking too far out to me? i could grind out the intake port of the head the few mill differences?
sorry for the blurry pic  :P
« Reply #5 on: June 28, 2009, 10:44:48 PM »
230351445511   on ebay now, looks black 202 to me,
lol,just seen ur pictures of comparison.  nothing a bit of silastic might fix.
marty
p.s. a black or blue 202 head are supposed to be very similar to a red yella terror ie/ bigger valves. , only with the smaller red ports.
« Last Edit: June 28, 2009, 10:47:02 PM by marty »
« Reply #6 on: June 28, 2009, 10:50:37 PM »
just get someone 2 aluminium weld up the vk manifold inlet ports a bit,
close em up a bit.
marty
« Last Edit: June 28, 2009, 10:55:35 PM by marty »
« Reply #7 on: June 28, 2009, 11:06:22 PM »
close em up a bit.
marty
that's what im thinking.... or cut and weld the  red face plates onto the vk manifold? save a lot of time with the building up process????
i have to get a few things closed off on there anyway...
maybe you can clear something up for me while your in the mood to part with knowledge....
do i still need a charcoal canister and all that anti pollution crap if im straight gas? the friend was saying i can rip it all out?
« Last Edit: June 28, 2009, 11:21:50 PM by able »
« Reply #8 on: June 29, 2009, 12:30:18 AM »
rather than weld the manifold id try puttin a vk head on, im sure they fit,
but get a few opinions anyway.
should be heaps better then a red yella terror as it will have the bigger inlet ports,
ull never get a red heads ports as big.
to the best of my knowledge the charcoal canister is for petrol only,
best check with a gas conversion place though.
marty
« Last Edit: June 29, 2009, 12:33:56 AM by marty »
« Reply #9 on: June 29, 2009, 07:21:45 AM »
What is the magazine you are reading?
I run a VK efi manifold on a straight gas setup and I highly recommend it.
I also have a Voodod cam, Yella Terra head, and other goodies. The power is awesome. People think the van is a V8 the way it goes, and how I drive it.
Check out the 2 threads:
GRUNT HUNT 202
http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=399.0
Question on lpg dual fuel
http://www.buga.com.au/index.php?option=com_smf&Itemid=2&topic=352.10
There are pictures there of my setup on the second thread.
