  • Dot Guests: 270
Author Topic: Blue Motor Holden Heads  (Read 2620 times)
autocat21
« on: June 21, 2009, 09:12:29 PM »
O.K. Guy's Oh and Girls, A Question for you?
Did Holden Make a Early and a Late Model Blue Motor Head?
The Reason I'm asking is as follows: I would normally say that a Blue Motor head has 4 Bolt holes on the side at the front around the #1 spark plug for the power Steering pump.
Problem is I aso appear to have 2 Heads with out these holes in the Head yet seem to be Blue Motor Heads one of the heads is actually on the Van I have with the Blue motor Manifolds on it.
Photo's Below.
autocat21
Re: Blue Motor Holden Heads
« Reply #1 on: June 21, 2009, 09:21:55 PM »
As you can see in the first 3 photo's the only hole on the side at the front of the Head near the #1 spark plug is a hole into the water Jacket for the Temp sender unit which the Red Motor Heads dont have.
The last photo is of another Head which has the 4 Bolt Holes around the #1 Spark Plug which would indicate to me without out looking at the ports to be the standard Blue Motor Head.
