  • Dot Guests: 233
Author Topic: Stud Pattern ???  (Read 13834 times)
Offline silverado
Re: Stud Pattern ???
« Reply #10 on: June 21, 2009, 08:30:48 AM »
Cool mezzmo, shane in NZ most trailers use ford or holden stud in 14 or 15" rims.
Trojen trailer parts one of the big after market suppliers for trailer bits also use these patterens.
I have found a local company that will make certifiable addaptors to any pattern I want for around $220.00 a pair.
Rusty
Rusty
« Reply #11 on: June 21, 2009, 09:19:00 AM »
Whats the problem with the CF pattern?
Where I live the roads are very bad. If you are a long way from home and hit a big pothole and bend a couple of rims, you have a better chance of getting home if the CF has Holden or Ford stud pattern rims.
More mag wheels are available with a standard stud pattern
Offline silverado
« Reply #12 on: June 21, 2009, 01:47:41 PM »
So true hence my reason for wanting to change, the second hand wheel selection is bigger and much cheaper.
Rusty
« Reply #13 on: June 21, 2009, 02:34:17 PM »
Must be hard living in down town mexico :P
I have just got back from the local BCF and they have 2 galv steel rims with bedford pattern in stock. The Kratzman boat place down the road has 14" galv, painted steel, and alloy bedford patterns in stock also ;)
« Last Edit: June 21, 2009, 02:36:16 PM by ShaneJ »
« Reply #14 on: June 21, 2009, 03:44:33 PM »
same here Chris the RTA  think its ok for us to have to drive on shit roads, but i suppose its not like were paying enough money through rego,fuel,insurances or other for them to think otherwise.
so looks like NSW RTA  roads are the worst around, thanks RTA.
cant even get em 2 fix the potholes in front of my place that keep me awake every 30 mins 24hs a day because of all the big trucks doing 80 to 90kms kms an hour over them.
sounds like frigging thunder.
thanks RTA
« Last Edit: June 21, 2009, 03:48:37 PM by marty »
Offline silverado
« Reply #15 on: June 21, 2009, 06:27:05 PM »
You gotta be takin the pi#$, why would I want to put gal steel rims or boat trailer alloys on a custom van  :P :P
Rusty
« Reply #16 on: June 21, 2009, 06:42:00 PM »
You're the one worried about needing a wheel quickly when you damage one in a pot hole ::)
Offline silverado
« Reply #17 on: June 21, 2009, 06:50:14 PM »
Not me Shane That was Blackbedford, he's worried about fallinng in to a black hole, with a black bedford it could be sometime before he's discovered missing.
Im in NZ we fix our pot holes, well prety smartly anyway.
Rusty
Rusty
« Reply #18 on: June 22, 2009, 06:12:39 AM »
« Reply #19 on: June 22, 2009, 10:32:41 AM »
You guys in NZ don't have any wheels that are made locally?
