  • Dot Guests: 231
Author Topic: Stud Pattern ???  (Read 13798 times)
Offline silverado
Stud Pattern ???
« on: June 20, 2009, 11:15:44 AM »
Anyone tell me if the CF stud pattern is the same as anything else, eg ford 5 stud ?
Rusty
Re: Stud Pattern ???
« Reply #1 on: June 20, 2009, 11:25:29 AM »
Nothing worthwhile.
Offline silverado
« Reply #2 on: June 20, 2009, 01:23:03 PM »
that would suggest that it matches something then ??
so im not near my beddie, what is the pcd on a beddie ??
Rusty
Rusty
autocat21
« Reply #3 on: June 20, 2009, 01:23:59 PM »
I'm led to believe that the Hoden Rodeo is supposed to be the same.Don't hold me to it thou.I nearly bought a Van for parts about 12 months ago and it had a set of wide rims on it, the Mechanic was the one who told me that they were off a Rodeo.I took too long to make up my mind on wether or not to pay a $100 bucks for it. I went back 2 weeks later and the bloke had  crushed it so never got to check out wether he was correct or not. :(
« Reply #4 on: June 20, 2009, 05:05:51 PM »
Stated on a previous thread is that the 5 stud Landcruiser is the closest. It is usable but not perfect.
Offline silverado
« Reply #5 on: June 20, 2009, 06:32:33 PM »
Ummm in a word Bugger but thanks guys, did a bit of research CF PCD is 5 x 152 and way out there in a world all of its own.
Yep the transhit van is close too and one or two of the 4x4's, but if ya made an adaptor to 5 x 114.3 then there is a plethora of wheels that will fit.
So thats an option, anyone running wheel stud adaptors on here ??
Rusty
« Reply #6 on: June 20, 2009, 06:38:27 PM »
Tried to get some made not long ago but no luck. Ended up changing axles and currently doing disc front end with matching stud to rear. Not a lot of people will do those adaptors anymore, are they legal in NZ?
Offline silverado
« Reply #7 on: June 20, 2009, 06:42:23 PM »
yes they are legal, but must be bolted to existing studs and then new studs offset should also be on the low vol cert for vehicle.
What axle/disc and stud have you gone to and have you docoed the change for the rest of us nosey BUGA's  ;)
Rusty
Rusty
« Reply #8 on: June 20, 2009, 08:31:57 PM »
Whats the problem with the CF pattern? Good trailer shops will have alloy and steel rims in the bedford pattern and a lot of small tractors also use the bedford patten.
« Reply #9 on: June 21, 2009, 07:55:14 AM »
Went to Pre AU ford pattern - as the front discs are new i had the stud pattern drilled from blanks. Took the Diff to a specialist who redrilled the axles and drums to suit. Not much to doco i'm afraid.
