  • Dot Guests: 270
Author Topic: 68 Bedford bus  (Read 7422 times)
Offline Vanders
  • probationary
68 Bedford bus
« on: June 13, 2009, 12:17:09 PM »
Gidday all hope someone can help me out I have a bus that had a 6cyl but has been converted to a Holden V8 can anyone tell me if in 1968 did bedford use V8's in there buses.could say me a huge headache cheers Alex.
Offline silverado
Re: 68 Bedford bus
« Reply #1 on: June 13, 2009, 03:03:37 PM »
As a classic Bedford bus owner i can tell you Bedford buses have only ever been fitted with three makes of engine from factory, Perkins diesel, Bedford Diesel and petrol and Leyland diesel and petrol engines.
They were never fitted factory with a GM V8 although some may have used Perkins V8 diesel's at one point in time.
This would only have been in the bigger long haul coaches and composits.
Rusty
1967 Bedford VAL
Twin steer
11 meter bus
Rusty
Re: 68 Bedford bus
« Reply #2 on: June 14, 2009, 12:50:57 AM »
Where are you?
I guess your problems are RTA related.
The RTA have listings of what the manufacture specifications were for each model in each year. If your bus is not to their specification you will need an Engineers Report. That is when it can get difficult.
Offline Vanders
  • probationary
Re: 68 Bedford bus
« Reply #3 on: June 14, 2009, 10:40:13 AM »
Thanxs fella's looks like ive got a few headaches ahead
im in victoria. Im debating to get a roadworthy done on it at least it will
tell me if i need engineers report.
cheers vanders
Re: 68 Bedford bus
« Reply #4 on: June 14, 2009, 11:01:39 AM »
Hey Vanders
welcome to the site.
A few questions for a start.
Is the Bus registered, was it when you bought it?
A V8 conversion in a bus or truck is common, and due to the design and strenght of the vehicle does not have the same impact as sticking a V8 in a passanger car, which needs other major components upgraded (eg brakes & steering).
Because the bus is already designed to carry a large weight all iits components should be up to task.
The main thing I think would be that the conversion has been done in a sound and proffesional manner.
Ring the RTA or talk to your Roadworthy guy ofr more info, but if everything is sound then you shouldnt have to many headaches.
Best of luck
