  • Dot Guests: 357
Author Topic: Making an Auto from a 3 speed manual  (Read 6280 times)
Offline Kirk
« on: June 03, 2009, 03:34:46 PM »
Hey all...
Well due to some circumstances, i maybe turning my van into an auto (dont ask me what type...it came with the van) and honestly id just like a rough idea of what a local mechanic might charge for such a conversion...
Thanks.
Kirk
(have the box only i think...maybe the bellhousing also attached)
Re: Making an Auto from a 3 speed manual
« Reply #1 on: June 03, 2009, 04:31:48 PM »
Kirk
What Engine are you going to run?
was the gearbox attached to the motor?
If its a holden 6 then it will be very simple - heaps of bits and pieces around for them.
Offline Kirk
« Reply #2 on: June 03, 2009, 05:39:02 PM »
red 202, nah it was in the back of the van....
Offline Worzel
« Reply #3 on: June 03, 2009, 09:02:46 PM »
trip to the wrecker will get most of the parts for almost nothing.
hard part is a shifter that is not than 8 inches long and halfway across the van
« Last Edit: June 03, 2009, 09:06:06 PM by Worzel »
« Reply #4 on: June 03, 2009, 09:30:27 PM »
kirk do it yourself!!!!!!! easy as. proably take you a couple of days for the first time thou:) especially with your job on the line!!
i had autos laying around. i just got rid but im sure i could get them back if need.. at hammers lol.
Offline Kirk
« Reply #5 on: June 04, 2009, 01:23:38 AM »
well mine is i presume still in the van....i did originally give it to Hammers just as a thankyou...but in this instance i think id like it back.
« Reply #6 on: June 04, 2009, 07:45:50 AM »
if your going from man to auto just dont forget 1 important THING CHANGE THE LITTLE BRASS BUSH (spigot bearing)
« Last Edit: June 04, 2009, 08:13:15 AM by craig »
« Reply #7 on: June 04, 2009, 10:34:56 AM »
very important!!!!!!!! i almost didnt do it. would have been disaster. apparently you can stuff the whole trany cause no support on the tourque converter.
« Reply #8 on: June 04, 2009, 12:26:09 PM »
i have a three speed auto in the shed that came in the back of the beddy.... pits and pieces around it....
was thinking about using it but i went the m20 four speed manual instead. (been driving auto minivans for what seems a lifetime and im sick of auto... makes me feel like a limbless prostitute)
its just sitting there and will go to the tip eventually....
« Reply #9 on: June 04, 2009, 01:48:32 PM »
my knowledge was the bush needed to come out completely or there,s no way ud get the torqueconverter to slip into the crankshaft.
every manual ive converted to an auto ive just taken the bush out n chucked it and not put anything back in
marty
« Last Edit: June 04, 2009, 01:50:10 PM by marty »
