  • Dot Guests: 273
Author Topic: LWB discs  (Read 27369 times)
Offline Worzel
LWB discs
« on: May 26, 2009, 05:00:40 PM »
so am i dreaming?
you get a valiant rotor (why valiant?)
 and machine it to fit on a bedford stub (why not holden ???maybe holden calipers wont fit inside 6 stud wheel)
then you get someone clever to make a hub conversion
bolt it all togeather and youŕe off to the engineers for a cert?????? ???
Re: LWB discs
« Reply #1 on: May 26, 2009, 06:45:00 PM »
isn't valiant the same as ford?
what about a nissan suv or something for disc's, they are 6 stud
Offline Worzel
Re: LWB discs
« Reply #2 on: May 26, 2009, 06:54:59 PM »
yeah, too many options.
just trying to get a tried and tested option because you could spend a long time on testing every rotor.
That sweet LWB that i can't afford used valiant rotors and he had a hub made.
I was at the wrecker today and those six stud drums are HUGE :o,
so depth is not an issue, just getting rotors inside the wheels.
Need to find out if holden will fit as i can use the caliper brackets of the standard disc conversion
Re: LWB discs
« Reply #3 on: May 26, 2009, 08:24:48 PM »
Remember that the Transit has disc brakes and is the same 6 stud pattern.
The 1984 lwb Transit has ventiated discs.
Offline Worzel
Re: LWB discs
« Reply #4 on: May 26, 2009, 08:44:11 PM »
yeah, but i can't find them -dba and reliance and a few others don't list them, and i haven't found one in a wreckers yet
I'm still hunting, if you can recommend a source.........
Re: LWB discs
« Reply #5 on: May 26, 2009, 11:08:52 PM »
not sure why val, the look great disks though that might be why.
, barry,s has commadore calipers.
marty
Re: LWB discs
« Reply #6 on: May 27, 2009, 08:28:05 AM »
Here are some photos to rev up the discussion.
I was told that the Transit disc setup could be fitted to a CFL, however the offsets look wrong.
Maybe the CFL hub can be machined to have a setup something like the 1984 Transit.
Standard Bedford Drum Brake:
Early Transit solid disc front end. The van had a Falcon 6 motor and single wheel rear end:
1984 Transit ventilated disc. The van had a Falcon 6 motor and dual wheel rear end:
Offline Worzel
Re: LWB discs
« Reply #7 on: May 27, 2009, 10:00:33 AM »
is the bedford drum deeper than the transit rotor ?
if so then a spacer would bring it out enough?
Without one of each on stub axles there's not much i can work out.
Will have to try JB's in dandenong, he does transits and bedfords,
Offline Worzel
Re: LWB discs
« Reply #8 on: May 27, 2009, 02:20:00 PM »
Phoned JB,
yeah sure no problem i can tell you.
Transit have smaller studs, but same pattern. didn't know about drilling to bedford studs.
He says he can give the bearing no. to bolt straight on, ???
Rotors $110 s/h each
Calipers $220 each (2 pot)
Make your own mounting plate.
Can't understand why no-one does it.
Still not sure, bound to be a few glitches on the way
Hmmmm, now all i need is a six stud LWB with a Hwy diff ;D
Anyone wanna swap a SWB with discs and diff?
Hardly ever gives any trouble ::)
Re: LWB discs
« Reply #9 on: May 27, 2009, 10:28:32 PM »
Did JB happen to say which model Transit discs he uses?
