  • Dot Guests: 378
Author Topic: Whos got gas?  (Read 39602 times)
Offline Clance
    • My Home Page
Re: Whos got gas?
« Reply #30 on: August 26, 2008, 07:03:18 AM »
Thanks Marty, they give me some idea about mounting the mixer and cut out. I gather your saying it still has the carby under that thingy under the air cleaner?
maybe chuck the photos in your gallery?
Clance
doofhard
Re: Whos got gas?
« Reply #31 on: August 26, 2008, 09:48:21 AM »
That's a pretty sweet set up and now that I see it I think it might work well for me with 2 tanks on the inside and then I can build a bed frame to sit on top with drawers underneath.
Re: Whos got gas?
« Reply #32 on: August 07, 2009, 09:26:25 PM »
i have two 65-70lt tanks.
how do they set them up?
do they have like a balance pipe between the two or do you fill them independently? do you run two gauges?
after reading that ben is fitting his own i have to ask is this legal? (no offense ben)  ;D
or can you mount everything at home (settle fellas im talking gas tanks and mixers  ;D ) and just get the gas fitter to run the copper?
Re: Whos got gas?
« Reply #33 on: August 07, 2009, 09:33:58 PM »
i had gas but i took something for it!
Offline westy12
Re: Whos got gas?
« Reply #34 on: August 08, 2009, 07:41:52 AM »
gday i run 2 tanks straight gas, 90l longways behind drivers seat and 50l behind diff. spare wheel goes in petrol tank mounts. 140l gets around 750kms with a 202 and trimatic. separate fillers with a switch between the two... ive got photos in my gallery.
take it easy.
Re: Whos got gas?
« Reply #35 on: August 08, 2009, 09:59:12 AM »
thanks westy12, having a look.
Offline Kav
Re: Whos got gas?
« Reply #36 on: August 08, 2009, 03:59:21 PM »
my swb has a 110litre tank, the afl lets it fill up to 80liters
this tank fits longways inside, drivers side between drivers seat and rear wheel arch
still have dual fuel
Jean-Claude Damn Van
Offline Mr Whippy
Re: Whos got gas?
« Reply #37 on: August 08, 2009, 06:01:31 PM »
Just wondering where you guys with gas have your tanks mounted and what size they are?
Thanks
Drivers side gas tank 55 litre
passenger side gas tank 57 litre
underside view of both tanks
They both hang a bit lower than I would have liked but that was the only I could get the capacity I wanted
Re: Whos got gas?
« Reply #38 on: August 08, 2009, 07:10:57 PM »
you don't have a problem with the exhaust being so close Mr whippy? tripy looking van too  :o
Offline Mr Whippy
Re: Whos got gas?
« Reply #39 on: August 08, 2009, 07:44:00 PM »
It is not as close as it looks able, so not really an issue for the tanks.
« Last Edit: August 08, 2009, 08:12:07 PM by Mr Whippy »
