  • Dot Guests: 209
Author Topic: Wheel bearings  (Read 4641 times)
Wheel bearings
« on: May 11, 2009, 06:34:43 PM »
Hey beddie brethren wheres the best place to get beddie wheel bearings from? and best price ? thanks .... Eddy
Offline Worzel
Re: Wheel bearings
« Reply #1 on: May 11, 2009, 07:11:39 PM »
every now and then i see them on ebay.com.uk , but having bought two from separate people and one not being a bedford bearing i was not thrilled - but if you pay by paypal you could probably get your money back.
front are easy if you've done a holden disc conversion, any bearing shop and cheap
Re: Wheel bearings
« Reply #2 on: May 11, 2009, 07:27:58 PM »
try this guy he may be able to help and I know his balljoints are VERY well priced
 jim withers of J W Classic Car Parts.
03 9762 6025 home or 0411 088 342
or       JWClassicParts@aol.com
Re: Wheel bearings
« Reply #3 on: May 11, 2009, 11:03:18 PM »
nah JW told me last tim ei was talking to me the cheapest rear wheel bearings he could find was $250.. which is more expensive than what i can get them for????
i was doing some research last week on using a different bearing very similar. but one bloke never rang me back and i forgot.. will get back to him cause it needs to be done. we cant afford to pay $500 for 2 rear wheel bearings!!!!!
Offline Rothu
Re: Wheel bearings
« Reply #4 on: May 12, 2009, 02:16:18 AM »
I just went to a Bearings/oil seal Wholesaler in Sunshine and they measured them and got them off the shelf! $20 each! That's for the front hub bearings (Bedford stub axle, holden machined rotor).
What I've learnt: DON'T go to any other place than a bearings wholesaler, you'll never get it. And DON'T say it's from a Bedford! Just say I want a replacement of these. (this is for ANYTHING Bedford!) They'll measure them and replace them. otherwise they'll be going through all of their books looking for Bedford things, never finding them and wasting your time.
« Last Edit: May 12, 2009, 02:28:23 AM by Rothu »
Re: Wheel bearings
« Reply #5 on: May 12, 2009, 09:43:51 AM »
yep I agree with Rothu, + there all soo different(Beddies) just remove the old and get them replaced, I also have kept a Log/all receipts and part numbers so you can soughta get organized when you need them  ;)
Re: Wheel bearings
« Reply #6 on: May 12, 2009, 05:06:34 PM »
great tips and advice boyz  ;D
autocat21
Re: Wheel bearings
« Reply #7 on: May 12, 2009, 10:30:49 PM »
When i was racing Supermods in Speedway we were running early Holden front stub axles with Ford hubs which we bought brand new complete with new bearings for $36 ea hub. We bought them from Statewide bearing Service.So for Bearings it pays to go to the supplier, but as mentioned above some times it's better not to let them know exactly what the bearings were originaly fitted to.We have found the same thing ourselves before let them measure them up and match a bearing set for you. ;) ;) ;)
