  • Dot Guests: 271
Author Topic: MY BEDFORD  (Read 13848 times)
Re: MY BEDFORD
« Reply #20 on: May 13, 2009, 08:36:29 PM »
Hay Scoop, not sure that painting the Auto is the right thing to do, as I am sure you will find the the oill gets a lot hotter. End result a lot more wear and tear on the box.
autocat21
Re: MY BEDFORD
« Reply #21 on: May 13, 2009, 09:05:00 PM »
Ben,here is a pic of my auto box
autocat21
Re: MY BEDFORD
« Reply #22 on: May 13, 2009, 09:09:23 PM »
and another one
autocat21
Re: MY BEDFORD
« Reply #23 on: May 13, 2009, 09:11:20 PM »
and yet another, I know should have them in the one post but had trouble with the size thing.
Offline Scoop
Re: MY BEDFORD
« Reply #24 on: May 14, 2009, 09:28:53 PM »
Quote from: Mark B
Also, what is the purpose of that large rounded piece under the actual pod?
I would say that its to protect the Pod from things coming of the fan blades (water, dirt, etc)
Quote from: Mark B
I was having hot air being blown up from the fan going straight through into the pod so I fabricated a shield to stop this.
No not really, it drives without any hassles temp is normal, if that was the case why would do we still paint radiators, blocks, sumps and heads. It does its annual trips from sydney to canberra for the summernats and from sydney to bathurst for the v8s with no problems - its a pleasure to drive
Thanks
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: MY BEDFORD
« Reply #25 on: May 14, 2009, 10:10:21 PM »
Thanks Scoop!
Did you happen to remember what model or part # that breather is on the head of your 202?
Also, the size of the pod? How did you realise you were getting hot air in straight into the pod? Performance lack or just physically felt it ?
 Sorry for all the questions, mate!
Have just installed a re-co'd 202 with extractors etc. similar to yours, after the last one siezed. Not quite as shiny and shmick as yours tho  ;D And looking to chuck on a Pod. Cheers
http://abakersdozen.com.au
Re: MY BEDFORD
« Reply #26 on: May 16, 2009, 09:20:42 AM »
heyautocat
so i take it your n ot changing gears from in side the cab at the moment.. thats a bummer..
do you have a mig welder or something. just make something up id say.. bend that braket thats on the trany shift.. and make a swivel dovey up thingy and yeh.. off you go..
ill take some photos of a working one.. if you dont have a mig or access to a welder ill have a look and see what i got to get you out of trouble..
autocat21
Re: MY BEDFORD
« Reply #27 on: May 16, 2009, 03:04:09 PM »
Yeah Ben it is a bit of a pain sticking my arm down thru the hole in the floor to change it to reverse or into park. Yes I have a mig and a stick or Arc Welder as well.If you could post some pics of what it should look like that will give me a head start, Thanks  :) :) :)
Offline Scoop
Re: MY BEDFORD
« Reply #28 on: May 20, 2009, 06:16:29 PM »
Thanks Scoop!
hey mark
no sorry dont know the part number and that but I can tell u I bought them both from rare spares...I found out about the hot air in the pod cause we had the probe thing up the exhaust testing the mixtures and found that when it was at a set of lights idleing the mixtures were all over the place but when driving it was perfect so we stoped and did a home made shield with some cardboard and cable ties and it fixed the problem so then I fabricated the little shield which stops the hot air been thrown up from the fan and also helps with the cool air coming from the bonnet scoop...
« Last Edit: May 20, 2009, 06:19:11 PM by Scoop »
