  • Dot Guests: 276
Author Topic: MY BEDFORD  (Read 13842 times)
autocat21
Re: MY BEDFORD
« Reply #10 on: May 10, 2009, 10:59:33 AM »
It's for the Van Ben, The truck has a 1 tonner 4 Speed manual box.
Drove the Van around the block for a bit after having the sports exhaust fitted, sounds good and Idling lumpy thanks to the Crow cam. 8) 8) 8)
Re: MY BEDFORD
« Reply #11 on: May 10, 2009, 02:13:34 PM »
send us a pic of what your missing and i should have one..
Offline Scoop
Re: MY BEDFORD
« Reply #12 on: May 11, 2009, 03:33:54 PM »
hey guys thanks for all the comments.
hey whats the box thing at the bottom of the sum bro?
its an extension on the sump that holds an extra 2L of oil and with a HP high volume oil pump...u can never have enough lube!:)
Question, are you using the original Auto shifter?
nope. its out of a early model gemini. the linkages bolt straight up.
how long was the rebuild....?
rebuild was about 6months, doing all the work myself at home.
Offline Kiwi CF
  • Sunshine Coast Kiwi
Re: MY BEDFORD
« Reply #13 on: May 11, 2009, 08:09:30 PM »
Sweeeeeeeeeet Bro
Well done on the hard work. 8)
Steve
Re: MY BEDFORD
« Reply #14 on: May 12, 2009, 08:20:48 AM »
oh so you extended the pickup as well i suppose.. that would have been a good idea on black beddy cause it was going through so much oil i wouldnt have had to fill it up so oftern hehehe...
anyway its off the road now until i get new motor gearbox and diff..
autocat21
Re: MY BEDFORD
« Reply #15 on: May 12, 2009, 09:54:42 PM »
I haven't got that pic yet but working on it :)
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: MY BEDFORD
« Reply #16 on: May 12, 2009, 10:51:01 PM »
Good work Scoop  ;D A1 looking Beddy - that 202 looks tidy too.
What's the model of the little air filter in the head of the 202? That's a great idea when running a pod filter :D
On my 202 there is one more hose that goes to the back of my original air filter (seems like a vacum hose or something)..I couldn't seem to see this on your motor, did you just block this up or did you never have one???Will try and post a pic of this = if it doesn't make sense..Cheers!
http://abakersdozen.com.au
Re: MY BEDFORD
« Reply #17 on: May 12, 2009, 11:38:54 PM »
Mark B
If you look closely at the first engine picture you can see the scavanger tube going toward the bottom of the carby.
That tube scavenges the fumes from the engine and runs it through the combustion camber, burning off any excess oil.
The on at the front is the breather, allowing clean air to be drawn into the engine.
Very tidy engin though :D
Offline Mark B
  • '79 CF SWB
    • Some of My Music
Re: MY BEDFORD
« Reply #18 on: May 13, 2009, 03:15:33 PM »
Thanks Warren!
A Huh! I see (light bulb moment) .. So if I were to put a pod on in place of the original air filter, does it matter where abouts this scavenger tube goes? I assume just making a spot for it to plug in, on the larger main pipe that feeds the carby, would be okay?
Also, what is the purpose of that large rounded piece under the actual pod?
Cheers for your help!
Re: MY BEDFORD
« Reply #19 on: May 13, 2009, 05:52:24 PM »
Quote from: Mark B
Yes that would work, but if you have a look at the second engine piture, just below the carby, you will see a bit of black tube, this is where the scavanger pipe normally goes into the manafold.
Quote from: Mark B
I would say that its to protect the Pod from things coming of the fan blades (water, dirt, etc)
Quote from: Mark B
No Problem
