  • Dot Guests: 61
[Today at 10:28:23 PM]
Author Topic: bloody axles  (Read 3222 times)
bloody axles
« on: May 07, 2009, 08:19:31 PM »
desparately need some help here - removed the diff from the van - eeeaaassssyyyyyy. Do you reckon i can get those bloddy axles out - what am i doing wrong. I have:
Undone the bolts holding the brake plate onto the diff housing.
Tried getting it to move with a slide hammer
Found what looks to be some sort of circlip in the diff under the bearing - liftted it and still nothing
Just broke my sledge hammer trying
i give up!! does anyone have suggestions? would be appreciated.
Mezz
by the way, dont give a toss about the old diff, just want the axles!!
Offline rubman
Re: bloody axles
« Reply #1 on: May 07, 2009, 08:39:48 PM »
give me a call mezz, i made a bedford axle puller,its down at the factory ;)
Re: bloody axles
« Reply #2 on: May 07, 2009, 08:55:48 PM »
Thanks, i'll give you a ring tomorrow
Mezz
Re: bloody axles
« Reply #3 on: May 08, 2009, 12:59:47 PM »
Woo Hoo - problem solved - took it Jeff at Jack Macnamara's Diff centre and jobs done!!! in about 2 bloody minutes i might add - man... the right tools make it look soooo easy.
Offline Worzel
Re: bloody axles
« Reply #4 on: May 08, 2009, 01:47:14 PM »
what did he use?
i can't get my axle out to do a wheel bearing, so before i make a puller i'd like to know what works
did it look like this?
« Last Edit: May 08, 2009, 02:16:11 PM by Worzel »
Re: bloody axles
« Reply #5 on: May 08, 2009, 04:59:47 PM »
Thats it Worzel - same.
Offline SandB
Re: bloody axles
« Reply #6 on: May 09, 2009, 11:17:40 PM »
Hi I had t use the oxy set and a slide hammer.  Price for new bearing, between $200----$250.
Cheers Brian
" BEDDIED AT LAST!!"
Re: bloody axles
« Reply #7 on: May 09, 2009, 11:48:06 PM »
i used the oxy once but i wont do that again.. i dont think its good for the housing.. i just use an old rim bolted onto the axel. smak it real hard with a sledge hammer. most likely destroy the rim but youll get any axel out in my experience.. ive pulled out probably about 10 by now..
Re: bloody axles
« Reply #8 on: May 11, 2009, 03:56:33 PM »
The tool that Worzel is looking at brought my axles out so quick and the upside, the bearings were removed without any damage at all - obviously a lot to do with the force of the slide being dead centre - as opposed to the way i was trying to do it. Highly recommend it!!
