  • Dot Guests: 252
Author Topic: Power Steering Conversion  (Read 28517 times)
Offline silverado
Re: Power Steering Conversion
« Reply #40 on: June 13, 2009, 06:59:26 PM »
You can do it with a grinder but it pays to get in to the pool first and then do it underwater with the ginder.
This stops the shaft from heating up... ;) ::)
Rusty
Rusty
« Reply #41 on: June 13, 2009, 10:36:45 PM »
that sounds a little dangerous rusty.
id just take it to the snow when im going next week:)) do it in the snow. that shouuld then pass the SA regs.
whats regs anyway?
« Reply #42 on: June 14, 2009, 10:07:47 AM »
Ok Rouge, will agree an engine is a important thing to have, so maybe this before the power steering then............ :D
Offline silverado
« Reply #43 on: June 14, 2009, 01:12:20 PM »
well i cant work out how the SA boys would know if you did it with a grinder or cold cut it.
Yes i know, if you heat the shaft its weaker ..... :P
The ginder is fine in the pool just wear your gumboots so your not grounded  :o
Rusty
