  • Dot Guests: 308
Author Topic: bell housing question  (Read 6953 times)
« on: May 04, 2009, 03:34:09 PM »
im using the same bell housing/clutch from my three speed for my four speed but i seem to have run into a problem...
i just lifted the old 186 with the gearbox still attached from my front end and their seems to be a slot/hole at the top of the bell housing.
im suspecting it should not be there????
if it is due to wear would it be from rubbing on the beddy frame somewhere or from inside?
if is needs to be fixed it would need to be tig wielded yes?
can supply photo if needed.
hammers_spanners
Re: bell housing question
« Reply #1 on: May 04, 2009, 04:17:44 PM »
Able put up a pic.
« Reply #2 on: May 04, 2009, 04:57:44 PM »
hammers_spanners
« Reply #3 on: May 04, 2009, 05:35:34 PM »
Normal - no problem I have another here without as well as one with??
« Reply #4 on: May 04, 2009, 06:05:39 PM »
yeh same ive got both..
« Reply #5 on: May 04, 2009, 06:25:06 PM »
ok then....
seemed rough around the edges like it was due to wear...
what is it a breather? do i just leave it or is it supposed to have a hose with a filter to keep out the dust?
« Last Edit: May 04, 2009, 07:34:52 PM by able »
hammers_spanners
« Reply #6 on: May 04, 2009, 08:40:26 PM »
Leave it, must be a breather.
« Reply #7 on: May 04, 2009, 11:50:10 PM »
I was reliably informed that it was to relieve air pressure buildup at very high speeds and is standard on most bellhousings. It is only roughly cast as the air doesnt care.
« Reply #8 on: May 05, 2009, 10:01:31 AM »
thanks all.
im officially pretending its not there  ;)
« Reply #9 on: May 05, 2009, 07:28:23 PM »
pretending whats not there?
