  • Dot Guests: 270
Author Topic: Heater problems  (Read 4881 times)
Offline oquip
Heater problems
« on: May 03, 2009, 05:31:45 PM »
  Hi,
     I have a 1972 C.F Bedford Bedouin Campervan,re-powerd with a 173 with auto trans.
     Can any members give me a few clues on how to hook the original heater system up to
     the 173 motor.
                         Warren,Thames N.Z.
Re: Heater problems
« Reply #1 on: May 03, 2009, 06:11:43 PM »
well the heater fan is just an electric motor. so you just need to run power to that with a switch so you can turn it off and on.
and the actual heater core is just water plumbing from the cooling system. im not quite sure if it matters which way the water flows through the heater core but i think from memory it should run in the firewall side and out the facing the engine side.
will try remember to take some photos tommorow.
is your vehicle on gas?
Offline oquip
Re: Heater problems
« Reply #2 on: May 03, 2009, 06:55:39 PM »
Thanks Ben,no its not on gas.
                      Warren.
Re: Heater problems
« Reply #3 on: May 03, 2009, 09:16:21 PM »
i have these two pics i made for myself before taking mine out to remind me of how it needs to go back. should be what you need as it was a 186...
« Last Edit: May 03, 2009, 09:30:31 PM by able »
Offline oquip
Re: Heater problems
« Reply #4 on: May 04, 2009, 07:08:13 AM »
Hi,
   Sorry Able,no pics.
                Warren.
Offline Worzel
Re: Heater problems
« Reply #5 on: May 04, 2009, 09:20:58 AM »
there are two pipes at the right of the thermostat housing that were used for the holden heater, they probably have one hose folded over blocking them off.
these connect to the heater core.
« Last Edit: May 04, 2009, 09:27:23 AM by Worzel »
Re: Heater problems
« Reply #6 on: May 04, 2009, 09:35:07 AM »
Hi,
   Sorry Able,no pics.
                Warren.
you need to change something in your settings... i can see them fine.
click here and have a look at them in my gallery...
http://www.buga.com.au/index.php?option=com_gallery2&Itemid=21&g2_itemId=6026&g2_page=2
they are at the bottom... named heater and heater2.
you can click on them to enlarge them.
if i remember correctly you might have to drill out the blank facing up on your water pump for one of the hoses..... not 100% on that though.
« Last Edit: May 04, 2009, 09:39:40 AM by able »
Re: Heater problems
« Reply #7 on: May 04, 2009, 10:39:39 AM »
Nope, sorry, it's something you've done. I can't see them either and there's nothing wrong with my settings.
Re: Heater problems
« Reply #8 on: May 04, 2009, 12:20:03 PM »
I think it might have been Ben in the past having problems viewing pictures when otheres wernt.
I Think he went in and deleted all cookies an fixed his problem.
By the way I can see the pic's
Re: Heater problems
« Reply #9 on: May 04, 2009, 12:35:27 PM »
I can see them now so something has been changed.
