  • Dot Guests: 310
Author Topic: Different Diff  (Read 4669 times)
autocat21
Different Diff
« on: April 24, 2009, 09:05:10 PM »
Anyone able to Id this second diff ? this one is in the van.
autocat21
Re: Different Diff
« Reply #1 on: April 24, 2009, 09:16:43 PM »
Here is another pic of this Diff. :) :) :)
hammers_spanners
Re: Different Diff
« Reply #2 on: April 24, 2009, 11:11:31 PM »
Looks like a Foulcan (Falcon) maybe XE XF as it has the Watts Link mount on the housing cover.
Re: Different Diff
« Reply #3 on: April 25, 2009, 04:30:55 PM »
hey autocat definatly a falcon has it been cut & made longer or is it standard length Cheers Reid
Re: Different Diff
« Reply #4 on: April 25, 2009, 08:13:18 PM »
looks standard width to me..
Offline john
Re: Different Diff
« Reply #5 on: April 25, 2009, 10:03:27 PM »
diff is 78 series borgwarner, rear cover is later model ford, it may have 25 spline 2 pinion hemisphere, but if your lucky it  may have 28 spline 4 pin ctr, check by pulling 1 axle, or remove rear cover.
autocat21
Re: Different Diff
« Reply #6 on: April 26, 2009, 01:23:03 AM »
Thanks again guy's
Not sure if it's standard size or not shall shall measure it up,next door has a  6 cyl EF falcon sdn so shall compare the 2 diffs. :) :) :)
