  • Dot Guests: 297
Author Topic: Diff Id  (Read 5770 times)
autocat21
Diff Id
« on: April 24, 2009, 09:02:35 PM »
Anyone able to Id this Diff ? :) :) :)
autocat21
Re: Diff Id
« Reply #1 on: April 24, 2009, 09:14:17 PM »
Here is another pic of the Diff.
hammers_spanners
Re: Diff Id
« Reply #2 on: April 24, 2009, 11:14:01 PM »
This is a HQ - WB commercial vehicle van, 1 ton or ute diff. The "ears" on the center housing have no holes for the control arm bushes.
Re: Diff Id
« Reply #3 on: April 25, 2009, 08:15:39 PM »
yep salsbury..
Offline john
Re: Diff Id
« Reply #4 on: April 25, 2009, 09:49:21 PM »
this is a salisbury from holden 1ton ute and panelvan, sedan diff doesnt have leaf spring mounts.       ps, if you need a rebuild or ratio change i do them, cost 140 for kit 180 labour, im in preth metro, 93447721. john.
« Last Edit: April 25, 2009, 09:55:26 PM by john »
autocat21
Re: Diff Id
« Reply #5 on: April 26, 2009, 01:09:44 AM »
Thanks guy's
Was told that it had been put into a drag monaro for a run but they blew the diff centre.So not sure what condition the internals are in will have to pull it a part and have a look.
Good to know what it is thou so i know it's worth having a better look at it.
Thanks :) :) :)
ajax_daze
Re: Diff Id
« Reply #6 on: April 26, 2009, 06:08:54 PM »
Hey john, I was wondering if you can re drill the stud axle from Bedford stud Patten to pre AU ford pattern as well as rebuild and change diff ratios? I’ve been looking for someone to do it for a while.  :)
Re: Diff Id
« Reply #7 on: April 26, 2009, 07:38:32 PM »
Yep ..Same diff as in my truck. A little narrow but wider rims and tyres make it look much better.! ;D :D
cheers..johnno
autocat21
Re: Diff Id
« Reply #8 on: April 26, 2009, 07:57:16 PM »
Thanks John.
Handy to know, when I'm ready I'll give you a call.
autocat21
Re: Diff Id
« Reply #9 on: April 26, 2009, 10:10:48 PM »
Jonno,
My little Beddie truck still has the standard duel wheel diff under it currently.
But the Van apparently has a Falcon Diff.The one tonner diff may make it under the truck eventually. 8) 8) 8)
