  • Dot Guests: 371
Author Topic: v8 running gear for sale $500  (Read 4759 times)
Offline strez
« on: April 24, 2009, 05:35:40 AM »
run out of time , money and space reluctant to let go but has to . $500 for
holden 308 turbo pattern
turbo 400
chev 12  bolt diff
engine been stripped and needs rebuild was going to put a set of exchange heads and ring and bearing kit about $1000-1500 depending on where you get your parts .
also comes with tailshaft , gearbox crossmember with tail shaft loop , radiator , exhaust , rear springs , chrome diff hat , gass carbie but also fuel pump , front crossmember with engine mounts to suit , carboard lay out of the hole you need to cut in the floor to fit engine .
can also throw in rusty short wheel base window van with 202 and trimatic
Does not come with disc brake front end , engine cover , petrol carbie
Re: v8 running gear for sale $500
« Reply #1 on: April 24, 2009, 09:40:51 AM »
bro pic didnt work.. does that mean its sold?
oh sorry there it is.. its worked..
